Spin out video. What if he turned the other way?
This is going to be a dumb question, but when he spins, he does the obvious thing. He countersteers, and locks to the left.
But, there is a point of no return (sideways) when the countersteering doesn't do anything.
My question is, when he is sideways, point of no return, what would happen if he turned the wheel right? Anything?
Skip directly to 5:29
IMO if he turns the wheel the other way he does a 360 away from the wall and his car lives another day. Either that or he could come all the way around and drive straight into the wall when he catches traction, which is why when spinning both feet in is best.
The hook to the inside at turn exit is a fairly common thing - he is certainly not the first to do it. IMO, that video is very educational. The reason for the specific advice for that turn is the barrier on the inside.
-Mike
ETA: Note all the other skid marks there - he ain't the first.
Which is why they teach you to have a bail out plan for every corner, some corners need counter steer, some need straight run off. This is something you explore on your first laps at a new track while you're learning your reference points and corner stations, plus talking to people who know.
I haven't driven Lightning but I did drive a Thunderbolt and, as an example, the known bail out for Turn 12 is straight off.
Looks like he actually didn't have a chance to go off straight. He had already lost it at turn in and was counter steering at apex and was sideways at track out. Just finished slide across track.
Yes, this is a very common thing at Lightning - Turn 1 and 5. That's why they have the inside walls lined with tires. This can happen at any track, but the hills make the car light at mid-corner, so you have to be easy with the throttle. Turning the wheel the other way should induce a spin, but you'd have to do it real early. Once the car's trajectory starts heading for the wall, there's nothing you can do.
Here's a video of me at turn 5. I gave him racing room, but got punted. I just drove off. There's plenty of room out there. If you try to keep it on track, you end up in the inside wall. This was in a race, so I was quick to get back on. In a DE you should wait for the corner worker to signal you back on.
Note, I'm a beginner.
I rewatched the video in slow motion.
Right at 5:39, he gets 2 wheels off.
Normally, here, you'd just steer straight, and run off the left grass, safely.
Just like Stooge does in his video.
But, at 5:39, he's not going straight. It's oversteering.
So, he then steers slightly left to correct the oversteer.
The car continues to oversteer, so he locks the wheel left.
Then the car goes sideways.
Could he have stayed on the grass?
If he did not countersteer, I think he would have spun, but on the left side?
I guess that would have been better, but it's probably hard not to try correcting.
The Penguin King
This is what I saw also. It was not a two-off that he snap-hooked to the other side. The car was basically out of control by apex. Completely different type of situation.
https://youtu.be/gS4b43dgV2E?t=5m29s
He did not brake enough. Car got light at turn in as it does there. Combined with too much entry speed and no throttle to settle the back end and it was gone.
It's not a rear engined car is it?
