NA 944 Guys. Air intake question
Hi All;
I am working on my SP2 944. Planning my first race at Summit. The previous owner routed the cone filter for the cold air intake, through the drivers side fender opening and mounted the cone in the fender well. It's positioned front of the tire, tucked up into the fender. I'm concerned that the filter will be exposed to dirt, rubber, and potentially water. Is this a valid concern? Should the cone filter be re-located inside the engine compartment? I've seen video's where a box is created just behind the removed headlamp with fresh air routed to that area.
Comments and suggestions welcome. If pictures are needed I can take them tonight. Thank you very much.
Don
Don
Hi All;
Don
Don
remember, ram effect is at MOST less than .05psi at high speeds, that's less than a 1%. and with a very optimal intake too. temperature, is easier to figure out, but you will find with temp probes of wheel well vs engine compartment, that those differences are very small tool however, very easy to make covered box that is fed by oncoming air if you want to squeeze the last few ponies out of the intake.
Just as a data point, this is what our air filter looked like after 4 hours. This is a stock air filter with the stock snorkle. We'll either need frequent cleanings, or another solution for our intake too.
you should see mine after a day at Laguna. filled with sand! funny though, my inlets are two inlets above the radiator and the base of the windshield . cant even imagine the mess if i had mine in the wheel well!
Don,
I have never experienced a cone filter on these cars that actually increased power to the point that it makes it worthwhile. The data and experience seems to show that the stock location with a clean filter is the best place. I just attended a PCA club race, and their was a number of very dirty cone filters on 944 cars. The SP2 winner had a stock air box. Hope that helps.
P
P
Cool air to your intake, even with no ram effect, can make a measurable hp difference so is worth having. I'm not familiar with the 944 stock airbox, but if it gives you air from outside the engine compartment, personally I'd take that over a cone filter.
all stock air systems provide air intake out of the engine compartment. its all about pressure drops . people Think that a cone filter will provide less restriction and that is not always true. its easy to measure with Sunx sensors. ive done a lot of this. its better to just leave the stock system in place, with an aftermarket KN filter in that, and run at the track. sometimes the engine compartment at speed is not that warm. usually there is a lot of air flow through this area. you need temp sensors to know for sure. there is not a lot of power there either way, most of which would be in ram pressure, but you need bumper feeding inlets to do this. (which also do both ram and air temp improvment)
It isn't difficult to keep a couple filters on hand.
I'm interested in additional pictures if you don't mind posting them.. Thank you guys for all the comments.
Don, has the car been tuned/chipped? If so the tune will be optimized with the current set up. If the car has a Stock ECU chip the stock air box is best.
Picture of how I have my intake on the of the cars.
I could not figure out how to down load these pictures. The first 2 pictures show the air intake box with the top on. The next shows the air box with the top off. The last shows where the air intake is located.
https://rennlist.com/g/album/5780282
in many tests, we found that the AFM doesnt work as well with a tube attached to it, as it did with the stock air box. the stock airbox is pretty flow efficient. it would be interesting to do a back to back test with the stock /kN filter vs the tube and cone filter. the AFM has that funky flap door that is not that restricitve in itself, but the opening size is very small (only about 4 square ") making something that resembles a big plennum, with the stock bell (square bell mouth ) opening, might help. either way, very few HP found in these mods we have found.
