FS CCW Rims [FL] $1500
I am selling a set of CCW wheels, hopefully I can sell them locally, even though they are without tires and relatively lightweight
they are located in fort lauderdale if you want to check them out.
I had the tires removed but before that I asked the shop (auto glitz) to check for round. they told me they have a slight deviation on 2 rims but nothing that balancing weight can fix.
Price $1500, but let me know if that is not market price. I think I bought them for $2k used a few years back.
they are super light weight and they look awesome. fitment is perfect for the gt3, really on the edge of the fender. I assume it is 35mm offset but I can't guarantee it.
I can say they they don't rub on my 996 car. with lowering and camber they should go right under the fender.
they were mounted with Michelin pilot cup sports 235 front and 295 back and they were stretched a bit.
I'll get them measured tomorrow.
Right now I hope I can find a buyer locally. But if not shipping will be ok, It may cost $200 or something, with proper packing and UPS tracking.
These wheels are very pricey brand new, I think a set if like $6k or something. they are really stunning in person.
I'm going to guess they are actually 9's and 11's. That was the most common 996 fitment for years from CCW. When you measure it's from inside bead to inside bead not from outer edges.
That particular wheel had a lip on the rears when they were wider than 11".
Had a set of those in that exact finish which was discontinued. Absolutely loved them.
some other may chime in or you can search the forum, but I believe the 997.1 gt3 and 996 gt3 can use the same wheels.
I know that I sold an old set of my gt3 wheels to a guy who had a 997.1 GT3, we actually tried it on his car first and they fitted just the same.
unfortunately I don't have the exact offset.
mine are not stamped, only number I can see is inside the rim by the valve location and it shows 5810
Same number on all 4 rims. you could not see it with the tires on as it is engraved, rather manually, on the inside of the rim. Looks more like something an owner engraved for safety purpose.
Looking at #AUDION19S, my rims looks just like the one on his yellow car avatar. Flush with the body.
I checked, they are 10" front and 12" rear from the outer rim to outer rim,
I'll try to go back to get it from within the inside bead to inside bead, but I'd say each bead is half an inch so 9" an 11" sounds like that what they should be but I'll double check when I get to my storage
