Seneca RV
Seneca RV
Anybody have experience with a Seneca RV?
Yep.
2007. Good rig. Nice size, has most everything you need. Power is good for most hauls, loaded up with enclosed 20' (7000lbs or so) tows just fine. Up hills it would be nice to have a bit more power. Cruzes all day at 70 with reasonable mileage.
Good gen set, reasonable tank sizes, inverter and battery systems are simple and reliable. Only issues were a cracked exhaust manifold and microwave died. like most class c built on a truck chassis they aren't exactly the highest quality interior build. Crap falls off and rattles. It is a truck chassis so you have the engine noise up front but not any worse than any other C.
Thanks for the feedback. The ones from 2011 or 2012 have a Freightliner chassis and a Cummings 340/660 hp/t engine.
the 07 had the 300HP motor but about the same torque and chassis. All really depends on how much you want to tow. The rig I have on my list is a Dynamax 32, more $$ but a class above in quality and 1000ftlbs makes all the diff in tow.
