condition of my front rotors
Sebro slotted rotors, 7k miles.
As you can see there are surface cracks and there is abrasion into the slots.
The rotors still have lots of thickness, but is what you see on the pictures reason for concern?
You should replace them. Best case they will cause excess wear on the pads. You got good use out of them and they owe you no money.
I always carry my take off's as field spares. Hang on to them. Think of yourself as thrifty by not chucking them (I would chuck them)
Replace them but retain them as spares. The lip is the worrisome item.
The lip can be removed by having them resurfaced. The only thing I see in the slot is pad material. Have them resurfaced and see if the cracks are still there, sometimes they are just on the very upper surface. Autozone or O'Reily's can resurface them for around $30. If the crazing is still there then I would use them as awning weights.
Hope you don't mind me budding in, as I am equally questioning the status of my front rotors.. They are PFC slotted on a 997.2 GT3..
Any comments would be appreciated.. They have about 25 heat cycles on them..
No lip, but shallow axial surface cracking.
-Mike
Basic Sponsor
Rob,
Unless the cracks are going to the outside of the rotor or you can put your fingernail in the crack.
tHey should still have life left in them. Have had some guys tell me they have run them until the slot is about to go away. Curious are these 32MM or 34MM thick.
Rob,
Clark
ApexPerformance.net
Premier Racing Outfitters
Toll free: 866-505-2739
Direct: 843-299-0997
EM: chamerly@apexperformance.net
www.apexperformance.net
Save 10% on your next order over $75 on most items- enter Promocode Rennlist-10 on your next order or mention Rennlist during your phone order.
PCA Club Racing - National Sponsor
Clark
ApexPerformance.net
My .02 cents.
Driving on track is about confidence. Anytime I question the condition of my brake pads, rotors, or fluid. I change or bleed. I like to know that the car is going to stop when I need it to. Any doubt causes me to drive less confidently. And for the price to replace these items it's a no brainer. You'll feel better when hitting the brakes at 140mph.
Originally Posted by good hands
My .02 cents.
