AIM New MXS dash is now available
I just received my first shipment of MXS. These are the smaller version of the MXG, the color screen TFT (Thin Film Transistor). I personally felt that the MXG dashes were too large for most of our applications. The MXS is here to take on the MXL 2, if you think you need a color display. These units list for $2299 and come with the main harness, good for 4 channels, and CAN signal. If you need more than 4 channels or have a second CAN signal (like from your ABS unit) you can add an additional 22 pin harness.
If you purchase a new MXL 2, MXG or MXS dash, I'll include a quick connect harness with wire enough to connect you your ECU and power source. Since most of us will use a Smarty Cam with these new dashes, I'm also including a Data Hub ($60 dollar value) as well. E-mail me if you have questions. jerryaustin at verizon.net
