Best cordless impact wrench
Old 03-09-2018, 12:12 AM
  #91
CCA
CCA's Avatar
Originally Posted by pfbz
I don't think the 'mid torque' fuel was available when I purchased my 2763, looks like a decent option. I agree you don't often need 1,000 ft-libs of removal torque.
Does the mid-torque model have a 'low torque' forward mode? I looked online and it appears it does not... I use that mode all the time on my big Milwaukee for lug bolts... Runs the bolts on to about 90 ft-lbs, and final torqueing is done with a beam style torque wrench.
I suppose you could use a torque stick to achieve the same result if the mid doesn't have a torque limiter, but it's nice not having to deal with them.
The Mid-Torque does have 3 power settings. 1) seem to be only hand/finger tight. 2) I have know idea, wish they gave a spec. 3) is 400 ft-lbs tight & 600 loose. I like that it is a little smaller bodied than the 2763, so I can get in more locations.
Old 03-09-2018, 05:12 PM
  #92
docwyte
docwyte's Avatar
The mid torque has more torque than my old full sized Milwaukee. Looks like I'll get the mid size when I need a replacement...
Old 04-04-2018, 01:16 PM
  #93
ExMB
ExMB's Avatar
Received 1,314 Likes on 799 Posts
It looks like the Milwaukee is on sale at HomeDepot
Link
Old 04-04-2018, 04:03 PM
  #94
machschnell_RS
machschnell_RS's Avatar
Link
Thanks for the heads up - just ordered one.
Old 04-04-2018, 10:25 PM
  #95
AudiOn19s
AudiOn19s's Avatar
same, have been having issues with my old impact and jumped on this deal. Thank you!
Old 04-05-2018, 10:39 AM
  #96
Andrew.M.Cox
Andrew.M.Cox's Avatar
I've had a Panasonic Power Tools EY75A2X for nearly 10 years on the same battery. It's light, small, has three torque settings. I can usually remove the steel lugs on my 944, torqued to about 90 ft lbs.
Old 07-23-2018, 04:32 PM
  #97
996SPECticle
996SPECticle's Avatar
Does anyone use a Torque Stick and trust them enough to not check every time with a hand wrench? How about those "protective" sockets?
Ryobi owners, HD seeming still has a deal on theirs https://www.homedepot.com/p/Ryobi-18...1890/206736695 . I had 6 Ryobi 1+ tools and 3 batteries already so I bought the "tool only" and used with my old batteries and was mostly unimpressed. I then ordered the kit (Tool/Battery/Charger) with the newer Li4Ah battery and wow! For all the other tools as well. Gotta love HD taking my return over 90 days.
Old 07-23-2018, 08:45 PM
  #98
bkovac
bkovac's Avatar
I use torque sticks / dog bones all the time in order not to over torque the wheel nuts. Once done with the impact I complete wheel nut fastening using a torque wrench to my required wheel nut torque setting.
Old 09-03-2018, 03:54 PM
  #99
ExMB
ExMB's Avatar
Originally Posted by JackOlsen
Smartest choice: Ridgid. It will do many full changes on the same charge (I guess the unknown factor is how tight the lugs have been put on previously, but it's rated at 450 lb-ft), and then the important thing: it comes with a lifetime warranty, which includes new batteries whenever the old ones age out. Otherwise, you're looking at a 3-5 year lifespan for your batteries, at which point it always 'seems cheaper' to just buy a whole new tool/set. Then, 3-5 years later, you'll do it again.
Smarter still, it's way under your budget.
You can now get the bare tool for free
https://www.homedepot.com/p/RIDGID-1...011B/301996008
if you buy the new 9ah battery/charger kit
https://www.homedepot.com/p/RIDGID-1...C801/304740781
Who knows, maybe they will be nice enough to let you substitute
https://www.homedepot.com/p/RIDGID-G...11SB/303037082
for the free tool as long as you pay the extra $10 and thereby get another charger and a 4ah battery on top.
Old 09-04-2018, 11:42 AM
  #100
Scooby921
Scooby921's Avatar
I have the Ryobi impact wrench as well and it does the job. If I were at the track multiple times per month or running an actual race team perhaps I'd buy a higher end, more durable tool. For what I need at home a couple times a year it's more than sufficient. The the broad spectrum of other tools that use the same battery it's hard not to buy into Ryobi's kit. I really like their portable air compressor for track days as well (P731...the bigger one, not the little inflator). Set the target air pressure, turn it on, and it turns itself off 0.5 ~ 1 psi above the target. It's pretty accurate compared against my Longacre pressure gauge. Makes short work of reinflating tires after a track day. I can take one battery and share or take two and have a back-up if one of them happens to run dead.
I bought a set of torque sticks to avoid over-torquing the lug nuts / bolts with the impact, but I found the torque sticks to be incredibly inaccurate. Perhaps if I bought a proper high-end set they'd be better, but the $40 set I bought via Amazon is off by a wide margin. I think I'm using the 110 Nm stick to avoid over-torquing past 160 Nm. Both the 135 Nm and 160 Nm sticks pass torque well beyond 160 Nm.
Old 09-05-2018, 12:13 AM
  #101
38D
38D's Avatar
Good advice on thinking about this as a system. I have a 2 snap on; 1/2 drive for the big stuff, 3/8 for the normal stuff. 3/8 also helps a ton when dissembling stuff for normal repair work. 3/8 will take off lug nuts easily and is much lighter than most posted here.
Old 09-05-2018, 12:50 AM
  #102
kgorman
kgorman's Avatar
Had a very bad crash flipping and rolling because of trusting torque sticks. We walked away, but no, never trust torque sticks. Ever.
Old 09-05-2018, 11:17 AM
  #103
Steve113
Steve113's Avatar
Milwaukee Fuel - the best I ever used
Old 09-05-2018, 11:18 PM
  #104
Bull_D
Bull_D's Avatar
I have been "summoned" three times to help loosen axle nuts. once it was originally attempted with a milwaukee, once with a snap on, and once with a dewalt. the Ingersoll-rand spun the nut off all three times without any hesitation. they are all pretty darn good, but in my experiences the ingersoll has NEVER not gotten the job done. you actually have to use care installing nuts. no just hammering away.....
Old 09-19-2018, 06:44 PM
  #105
BF951
BF951's Avatar
Milwaukee Mid-Torque is on a one day special at HD. Includes 5 AH LI battery & Charger $199 delivered
HD Ad
Quick Reply: Best cordless impact wrench
