Help with Pedal Setup
I've performed a search and couldn't find a specific answer. Sorry if it's been asked and answered before.
I have 997.2 turbo. The edge of the break is 6cm away from the edge of the throttle when depressed to the same level. This obviously makes toe-toe downshifting basically impossible unless I'm wearing really wide dress shoes (which I don't think are the best thing for the track). The Toe-heal thing just doesn't work for me, I'm definitely a ball of the foot roll over guy. As a result I need to change the width of my gas pedal. My question is this. What is a good starting distance for the gap between the break and throttle? I'm sure this is a personal preference but I need to pick a good distance to learn.
I have one year of DE track experience.
Thank you.
Thank you.
Rennline has an adjustable pedal set-up...
http://www.rennline.com/Rennline-Rev...fo/A14.3P6059/
Gas Pedal only
http://www.rennline.com/Rennline-Rev...uctinfo/A14.3/
Gas Pedal only
Do you mean the BRAKE pedal? And your HEEL?
If you have small feet, the adjustable pedals Doug mentions are very good. However, as you get more experience, you may discover that you are better & better at articulating your ankle, and the stock pedal difference is pretty good as is.
Is it not ok to roll your foot over and hit the gas with the edge of your foot? That's a technique that was shown to me by an instructor my Upper Canada Porsche Club DE weekend.
Sure it is!
Wide, hard dress shoes are the last thing you want to wear for effective heal/toe.. Too hard, not enough feel. A good driving shoe like a Pilotti or the like allows you to drive almost like you are barefoot. Very nuanced pedal feel.
I think Pilotti is no longer available, but there are other driving shoes around. Even soft sole Converses would be better. Nothing beats a good driving boot. But don't go crazy. Just get some decent shoes for now. (You are just starting). You want them too thin for long distance walking is what you want.
I don't like the Rennline Pedal extensions. They are useful as a learning tool. I used them myself, but it is all too easy to catch the extension with your foot while braking. Drove me nuts. I cut them off after a few weeks.
Have fun!
Have fun!
Thank you.
Thank you.
Jaylin
As mentioned above using the ball of your foot to heel toe is fine, that is what I do too. With regard to shoes, again as mentioned above, you should get some good driving shoes that will give you better feel.
There is not a set gap between pedals however 6 cm is a lot. I would try to get to 3cm and go from there. At 3 cm, you will find real driving shoes will span the gap easily to heel & toe using the ball of your foot.
Mark
Mark
Jaylin
Mark
Mark
I have some nice soft souled shoes that give me great pedal feel, but they were just too narrow. I'll start with 3 cm and see how that goes. First track weekend of the year this weekend!!! I can hardly sleep!
Rennline pedal set.
The brake and clutch pedals are slightly larger and the gas pedal extension (red) makes it easy to reach the gas from the brake. The gas is also adjustable fore and aft so it is at the proper level with the brake.
A simple and inexpensive solution may be to trace the outline of your gas pedal and make a cutout from 1/2" plywood. Fasten this securely to your gas pedal. Give it a try, if it does not do it for you just throw it away.This has worked very nicely for me. Not glamorous but gets the job done.
Ok, so I got the Rennline pedals. The black ones with the rubber grippies in the holes. Now my break and pedal are 3.5cm away from one another. The gas pedal is now 3.5 cm away from the edge of the break (instead of 6cm OEM). Also, since the gas pedal screws on top of the OEM it since a little more aft than before which is either going to be a good thing or be too close on hard breaking. We will see. Tomorrow is my first day at the track with them. I was driving around tonight working on my down shifting. Waaaaaaay easier now. Looking forward to the track tomorrow!
Thanks for everyones input!
-Jay
-Jay
Be really careful with these, it is easy to find yourself stomping on the brake in a heavy braking zone or a "both feet in" scenario and be squeezing the accelerator at the same time.
It takes some practice but the stock pedals are actually well placed, most of the time my big toe is the only thing on the brake pedal.
