997.2 C2S Alignment Specs
I've reviewed a ton of threads on this topic, so forgive yet another one as I'm hoping for some advice.
I use my 2009 C2S with SPASM as a daily driver. It is largely stock (ex brakes, r-comps) and I am unconcerned about tire wear. I have quite a few years of experience, run in black/red and data acquisition says that I do 2.12's at VIR Full on a good day. That being said, Porsche spec's require less neg camber up front vs out back, which I'm unused to. So, since its spring cleaning time - the car goes into the shop for a few things including an alignment touch up. What kind of balance would I achieve if I did the following: Front Camber: Maximum neg (maybe -1.25) Caster: Stock Toe: Stock Rear Camber: Front minus .2 (maybe -1.05) Caster: Stock Toe: 2mm / .25* TOE IN per side - 4mm total What do you guys think? |
Comments from anyone? Good one's that is?
