Getting Car Track Ready
I'm sure this is an ENZO
I need a list of things that you do to your car to get it ready.
1 - Flush brakes
1 - Flush brakes
True, but I was thinking "above and beyond."
In my experience the tech sheets vary quite a bit. Having a qualified and trusted technician go over the car is always a good idea (if you don't do that sort of work yourself). You can:
- visually inspect tires for wear, rotate/replace if appropriate
- if you have harness - ensure your seat belt blanks are in the car
- master cylinder should be flushed before storage (if you store your car) and do a caliper bleed every so often to keep fluid fresh during track season. I flush the entire system yearly and do caliper bleeds about every 2-3 track events. It's probably overkill but it's cheap "insurance" and very easy to do. It also is a chance to get a close up look at pads.
- flip brake pads if they are wedging, or replace as needed. Once at 50% I replace them. The wear significantly increases from this point.
- oil change at frequent intervals when tracking (this is obvious and more "cheap insurance")
- inspect the "moving parts" for wear, "wiggle" and tighten/replace as needed. This requires getting under the car.
- inside the car make sure everything is tight (seat bolts, cage/roll-bar, harness attachment points, etc).
I'm sure there are many other items that could be added. This is off the top of my head....
Upgrade any safety stuff you have. If you don't have them, harnesses and Hans system. When I got that setup I was able to concentrate on driving, not keeping my body in the seat. Much more fun, and safe.
+997
Already registered for my 2014 DE
