Tips on removing rubber streaks on clear bra?
Old 08-10-2013, 05:30 PM
Hella-Buggin'
Hella-Buggin''s Avatar
Default Tips on removing rubber streaks on clear bra?
After a few DE events this year I've got some rubber scars from debris. I simply clay the paint and it comes right off but it seems to really like the stone guards and clear bra. Any suggestions?
Old 08-10-2013, 06:42 PM
J richard
J richard's Avatar
Try simple green
Old 08-10-2013, 07:11 PM
SoClose
SoClose's Avatar
The more force you use, the more scratches you'll get in the bra.
At the track, I've found RRR to be the best for maintenance, between runs. A polisher with some cleaner ( at the track I use that cheap but damn good NuFinish) at the end of a track day/weekend.
Finally, for the deep stuff that won't come off with gentle pressure use Oil-Flow Safety Solvent, then immediately go over that area with soap and H2O.
Old 08-10-2013, 07:55 PM
skxf430
skxf430's Avatar
A lot of people like Mothers R3 rubber removal but I have found the TTR spray from Premier Mobile to be the most effective hands down.
http://www.premiermobilegroup.com/pf1_products.shtml
Old 08-10-2013, 08:05 PM
93 FireHawk 968
93 FireHawk 968's Avatar
Most of the "Spray" waxes work best. Easy on and off.
Old 08-10-2013, 09:45 PM
mglobe
The Penguin King
mglobe's Avatar
Mothers R3
Old 08-10-2013, 10:14 PM
Frank 993 C4S
Frank 993 C4S's Avatar
Wurth Multi Purpose Solvent. Spray and wipe off:
Old 08-10-2013, 11:00 PM
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
I would definitely send a PM to TOGWT in the Detailing forum.
https://rennlist.com/forums/members/48425-togwt.html
https://rennlist.com/forums/concours...thank-you.html
He is the undisputed expert in areas such as this...
http://www.autopia.org/forum/autopia...ce-myself.html
Old 08-10-2013, 11:08 PM
meteor10
meteor10's Avatar
I used Bug and Tar Remover ( by Turtle Wax ) it seemed to work well on the clear bra and the paint. Is this an okay product?
Old 08-11-2013, 05:02 AM
Jamie_GT3
Jamie_GT3's Avatar
Mothers R3 and haven't tried it yet, but Griot's has one out now that removes the tire marks as well...
For mothers, spray it on the area, let it sit for 15-20sec then wipe it off gently. If it doesn't come spray a little more and let it sit...
Old 08-11-2013, 08:09 AM
Rob996
Rob996's Avatar
Mothers R3 has been amazing.. I have a clear bra installed on the entire front up to the windshield. With a white car you really see all the rubber marks, this product simply sprays on and wipes off with little effort..
I'm sure there are other great products out there, I have only tried this one after not being able to remove the rubber with soap and water.
Old 08-11-2013, 09:41 AM
Kein_Ersatz
Kein_Ersatz's Avatar
Awesome Orange and then spray wax.
Old 08-11-2013, 10:49 AM
Flying Finn
King of Cool
Flying Finn's Avatar
Miracle Wash.
You will thank me later.
Old 08-11-2013, 10:56 AM
Blitz128
Blitz128's Avatar
I have used Mothers R3, Goo Gone, and Isopropyl Alcohol(drug store)... all work good on my car wrap.
Old 08-11-2013, 11:56 AM
Bull_D
Bull_D's Avatar
two of the best products i've ever seen.
http://www.plexusplasticcleaner.com/plexus.html
it is a great spray plastic cleaner/wax. i caution using some of the solvents, etc....it may clean off great, but it is damaging to most clear bra materials....either in the short run or sometimes the long run. rubbing alcohol is ok, removes some small hairline scratches.
this stuff is the bomb. i use it on paint, glass, clear bra, wheels. it's claims are spot on. super easy to apply.
http://www.rejex.com/rejex.html
Quick Reply: Tips on removing rubber streaks on clear bra?
