Harness
Old 05-14-2013, 12:36 PM
linzman
linzman's Avatar
I have used both G Force and Shroth Hans compatible belts. If using a Hans, the 2" upper belts are nice.
No 4 point harness though, don't think that's even legal for PCA DEs.
Old 05-14-2013, 12:47 PM
aj986s
aj986s's Avatar
x2 that 4 points aren't allowed with PCA, or many other DE/racing programs either. Some use for autox, with OEM seats.
With PCA, remember both people in car must be similarly restrained. AFAIK, 2" shoulder belts must be used with a HANS, whereas 3" can be HANS or not. I would recommend that passenger side be 3" for more flexibility. Driver side is up to driver.
Old 05-14-2013, 12:48 PM
mrbill_fl
mrbill_fl's Avatar
Schroth Profi III (IIRC) 6 pt. pull up. I like the little bar they put on the end of the adjustments...
g-force is fine.
are 5 points are even allowed today? ...
Old 05-14-2013, 12:57 PM
Matt Romanowski
Rennlist Hoonigan
which cost no drachmas
Matt Romanowski's Avatar
g-force is fine.
Yes, 5 points are allowed everywhere.
Not true on both points. PCA allows 4 points if they are vehicle specific. Scroth makes some, but I believe most of the fitments are BMW. If I remember right, I just saw some for newer Porsches.
2" belts are safe HANS or not. The original spec on 3" was becuase they couldn't make belts strong enough if they were any narrower. That is not the case anymore.
Old 05-14-2013, 02:08 PM
aj986s
aj986s's Avatar
Originally Posted by Matt Romanowski
......Not true on both points. PCA allows 4 points if they are vehicle specific. Scroth makes some, but I believe most of the fitments are BMW. If I remember right, I just saw some for newer Porsches.
And the learning continues.....
Interesting about the 4 point belts....they apparently tie into the car's existing seat belt buckle, and make use of the automatic retracting feature of newer cars. Fascinatingly simple...if your car is properly equipped.
http://www.schrothracing.com/tuning/...it-pro/qfp-bmw
Old 05-14-2013, 03:23 PM
white924s
white924s's Avatar
I have Schroth profi 2 HANS harnesses on the driver's side and non-HANS on the passenger side. I particularly like the cam lock buckle - it's very easy to get off if you need to get out in a hurry!
Also, I find the cam-lock buckle easier to put on than the traditional latch buckles because it's more intuitive to me (which helps when I can't look down to see what I'm doing with the HANS on).
Old 05-14-2013, 06:16 PM
dacbap
dacbap's Avatar
It's all about looking good
Old 05-14-2013, 06:38 PM
Coochas
Coochas's Avatar
And this is why it's a good idea to have Scotchguard on the seats.
Old 05-15-2013, 09:39 PM
mhm993
mhm993's Avatar
Consider comfort in choosing a 5 or 6 point. Marc likes 6, I like 5. Figure it out.
G-Force is a fraction of the price of the others. Same webbing and same inane replacement interval. You have limited choices in pull direction and the attaching hardware isn't as elegant. Such are the sacrifices when outfitting 3 cars.
THIS IS FOR DE guys. And yes, nine point belts are strongly preferred over 5, 6, 7, 8. If they made a 20-point we'd argue for that.
-- Mindy
Old 05-15-2013, 10:08 PM
911Königin
911Königin's Avatar
So, if I have a harness, I HAVE to have HANS?
You got it right
-- Mindy
I LOVE LIVING MY LIFE MY WAY!!!
Old 05-15-2013, 10:38 PM
Veloce Raptor
Veloce Raptor's Avatar
Received 1,414 Likes on 755 Posts
-- Mindy
Old 05-15-2013, 11:59 PM
rlm328
rlm328's Avatar
If you use a harness it is very advisable to use a HANS of some type. It is all about sudden stops and inertia.
Old 05-16-2013, 09:47 AM
aj986s
aj986s's Avatar
Originally Posted by Karen England
So, if I have a harness, I HAVE to have HANS?.....
The harness holds only your body in place. Your head is still dependant on your neck. A HANS prevents how far forward your head can go in a very abrupt stop, thereby limiting the stretch/damage to your neck and spinal cord.
I used to believe in neck collars, but have since moved away from them if using a harness. With a harness holding the body in place, the collar can become an inconvenient fulcrum for the neck in certain crash situations/angles. However, some people claim to like the collar as a "helper" to support the weight of the head/helmet upright, even with a HANS.
Last edited by aj986s; 05-16-2013 at 11:07 AM. Reason: collar...not harness. oops.
Old 05-16-2013, 10:10 AM
dan212
dan212's Avatar
I have always preferred 6 point belts. Putting a belt over my ***** makes me unhappy. but This is another good case for a six point belt...
Old 05-18-2013, 11:11 AM
mhm993
mhm993's Avatar
My assumption is that "Karen England" is female. Someone fill Dan in please.
-- Mindy
Quick Reply: Harness
