Toyo's new RR tire
#76
Have to disagree with J Richard. We still get 2 full weekends (5-6 days) out of a set of 4/32" shaved
RA1s on the SPEC 944. We run them until cord shows with ZERO lap time fall off. I can't do that with the Hoosier's on my 911 and can't think of any other R coumpound that will run to cords (and last 2 full weekends). I do agree that they don't last as well as they did a fwe years ago we used to get 3 + plus weekends. Still a damn good tire. Sounds better than 3-4 heat cycles and then they come apart on the track.
#77
I just received this from TOYO: TireRack, so far denies they've actually heard of a problem and asked for pictures, which I will send them tonight as soon as I take them.
Thank you for contacting Toyo Tires USA. In order to offer an inspection for warranty consideration please contact Tire Rack for the warranty process. You may also view the warranty located at www.toyotires.com . Should you have any further questions please reach us directly at 800-442-8696, M-F from 6:30 am to 5:00 pm pacific time.
We have opened a file in your name for further assistance.
Sincerely,
Consumer Relations
Toyo Tires U.S.A. Corp.
5665 Plaza Drive Suite 300
Cypress, CA 90630
800-442-8696
Connect with us:
-----Original Message-----
From: no-reply@toyotires.com [mailto:no-reply@toyotires.com]
Sent: Monday, December 03, 2012 10:55 AM
To: Contactus
Subject: Torgersen
Submitted on 12/03/2012 - 10:54
Submitted by anonymous user: [76.0.162.203]
Submitted values are:
First Name: John
Last Name: Torgersen
Email: johntorg2@earthlink.net
Telephone:
Street Address 1:
Street Address 2:
City: Beaufort
State: South Carolina
Zip Code: 29907
Reason for Contacting Us:
(Select all that apply):
- TIRE SAFETY
Vehicle Information:
Year: 1988
Make: Porsche
Model: 944
Tire Size: 225/50/R15(Ex. 205/50R17)
My Question/Comment is Regarding the Following Tire:
Comments/Questions:
I have had a delamination failure on 2 of four Toyo RRs on their 2nd heat cycle. I purchased these from TireRack about 3 weeks ago. I understand this is a common problem and would like to know what Toyo is doing to reimburse users of these tires for the cost of the tires, transportation, mounting and balancing.
Thanks for your help,
John
Sincerely,
Consumer Relations
Cypress, CA 90630
800-442-8696
Connect with us:
To: Contactus
Subject: Torgersen
First Name: John
Telephone:
Street Address 1:
Street Address 2:
City: Beaufort
Zip Code: 29907
- TIRE SAFETY
Year: 1988
Make: Porsche
Model: 944
Comments/Questions:
John
#78
I was skeptical as well, but after having a post tsunami shaved sets fall way off after 16hc I was surprised. I asked my toyo guy what the deal was and he said that the new compound has significantly less silica due to new California EPA requirements. He said the silica content is what determines the durability of the tire and we have the tree huggers to thank for this. Ultimately it will be affecting all tires compounds...anyway what I've been told...
#79
Newer RA1 does heat cycle out before cording now vs old days. Confirmed between a lot of us spec racers.
FWIW, the Nitto NT01 is a better tire and TOYO owns them. Wish they would use the Nittos in spec
#80
New RA1 sucks except when brand new. NT01 is very good, however.
#81
Edit:See the link in the next post below - it has all the info there, correctly formatted.
John, do you have any pics of your buddies tire? PM me when you get the chance.
#82
#85
I will ask if he took a picture. It sounds like Toyo isn't going to do anything for those who mounted the tires before their supposed fix. I'm still not sure I understand how to mount them even now.
#87
Thanks for the information. Do you know how to get replacements. Is it through TireRack? What do we do if the next ones have the same problem? It appears that some tires mounted properly have failed. I'm not too happy with the description of it as a cosmetic failure.
#90
Thanks John - I will pass it on.
I asked tonight wether the drive wheels recommendations apply to low HP cars (we don't spin tires much, at least with an LSD!). The answer is definitely yes, they do apply to all cars.
I am also told the recommendations are expected to be permanent, though research and testing into this issue remains very active/ongoing.
