Watkins Glen racers, what you should know
The one time (and hopefully ever) I early apexed the Kink at Road America, I did exactly what Gary described. Kept the wheel straight at 110 mph, let the suspension settle, and eased it back on track. Just be sure to let the suspension settle before giving steering input.
The corner certainly wasnt "nailed" but I thought I had the car set up, before the rumble, to run down it as it appeared to be pointed where I wanted to go (and I hope where I was looking), up the hill and to the inside of turn 9. The video appears that I was trying to turn the car to get back on track, but that initial yaw I believe was caused when the left front hit the water, soon to be followed by the rear and as you said, then I was just along for the ride.
This is a great forum to share, learn from mistakes or point out things at a track we that we all should be aware of..
From someone who is hoping to do my first run at the Glen this year, I thank you for sharing this. Glad you are okay, and hope you're back on track soon.
Rennlist Hoonigan
which cost no drachmas
This is a good lesson for many, many corners. We're always told to try and drive it straight off, but sometimes we forget to drive off as straight as possible. The downhill at Lime Rock is the same as here. People put two wheels off, then try and get the car right back on track. The key is to be patient (and have some big *****) and drive it with two off for a while until the car settles like Mike in Chi said.
Track walks at the Glen are one of the best things anywhere. There is so much elevation change, camber, and little markers to be found that it is amazing.
Sorry for the crash and glad you're ok.
Another perfect example of the unforgiving nature of the Glen. Do they really need those blue bushes right there? Unfortunately, that would have been a harmless spin into the grass at most other circuits. The Glen could be the best track in the NE, as long as you're on the pavement. I imagine they charged you for armco damage, too, didn't they?
I am glad he is OK
John H:
T8 is actually one of the easier turns to master at WGI. VR is totally right. I'll paraphrase what he said - maybe this will help:
Its vision.. The car goes where you look. If you look AT the turn, you will creep in and probably also turn in early: On any track..
Use left side visual references to control your vision which will help to maintain your line and avoid the creep. For example, the white line that goes down the left side ends with some extra paving to the left of the white line just around the ideal turn in (Doesn't matter what you think the ideal turn in actually is). Look for it. Other similar details. Look at things around the turn in. Anything to avoid looking to your right at the Apex when thats not where you want to go yet.
Don't look at things that can move!
Don't look AT the Apex before you turn in. It hasn't moved in years. This can be a very fast turn when done right.
This also applies well to T1 at WGI.
Gary
You are right.
I should have said.. Do more better at
You are right.
Thank yoou for sharing this tip.
At day's end, it's your health that counts--glad you're OK.
Gary
