Towing Stuff
Oh and noticed yours is a 4x4, way too soft for a good tow but a stiff spring screws up the terrain following you want for off road, with the bags you simply let the air out and your ready to go. The big dif that JR mentioned is the timberline setup has a gap and contacts the axle when loaded, the firestone is bolted between the axle and frame, you have to keep a ferw pound of air in them since they replace the rubber bump stops.
J Richard- thankx-
Looks like this place in Albany has all the options..... Springs, Timbren and Air bag systems...I will try to check it out this week. Thankx for the info/advice.
