Rennlist iRacing thread
#6362
A quick and dirty video of last night's round:
I set the camera to "Follow Most Exciting" and it looks like it focused entirely on Justin and I.
I did flip between different camera views to keep it somewhat interesting... some neat angles in there.
I might go back and cut it up for a highlight reel and make it (MUCH) shorter.
Was a good time though and with Phil, Justin and myself being so close in quali I thought for sure the whole race was gonna be a dogfight - especially when Phil wasted NO time making that move into the chicane!
I was really bummed he lost it on the exit. It would have been an awesome 3-way battle I bet.
Was fun chasing Justin. I had a few chances to get my nose up inside, we went side-by-side 2-3x... but I didn't have enough to make it stick.
Next time, Gadget. Next time.
#6365
The netcode shows that I tagged a wall in your replay Jim. My car was still straight on my end. I must have come really close though.
If someone wants to set up a session in the league, just let me know and I'll make you an admin in the league. Sean used to do it, but I haven't seen him around for a while.
#6366
#6368
Sorry if this has already been covered, but it's a little hard to catch up on 425 pages ;-)
Ok, I just started with iRacing and have two questions
I am looking for a car which is similar in handling and lap times to my ride (2009 C4S)
I picked the Miata Cup car, is there anything other you guys recommend?
This car feels like I am driving on ice: I am driving my usual lines and brake points on a track I know very well, but keep spinning out at places and situations which are no problem in the real world
#6370
Finally your choice of car is quite different from a C4S. The miata should be quite different as it's RWD front engined compared to your AWD rear engine. I think there is a version of the RUF RT12 that is AWD. It will have way more power than a C4S, but the dynamics should be closer.
#6371
The new Miata is also much more tail happy than the old (circa 2015) Miata. The circa 2015 Miata drives like, well, my Miata, but with more power. The new one drives like some? car, I guess.
#6372
JustinL nailed it.
If you were to put a cheap plastic (electric) wheel and plastic pedals in your (real) car it would be difficult to feel & drive the car, right?
I've driven iRacing in a SimRig with an AccuForce direct drive motor (google it) and the difference was night and day. Can you do iRacing with a cheap wheel? Absolutely, but you are going to be "driving the wheel" and will not feel the simulated car physics .. IOW, it won't feel "real".
Now if you tell me you have a $1000 set of wheels and pedals then I'd want to know what kind and how much time you've spent setting them up.
That would be the Ruf, no?
PS - Turn the tire noise (Options > Sound) way up. You'll hear the tires slide way before you see it.
#6373
Yeah - let us know what equipment you're using. What wheel, pedals, etc. and what's your display setup like? Single screen, triple screens, VR headset?
With a single screen and a <$300 Logitech setup, you're going to need to spend a bit of time "learning the sim". That's NOT to say that it can't be rewarding or even useful without expensive gear - just that, you're going to have to learn how to "tune in" to the bits and pieces from the sim to help you get and maintain control.
My guess is that you're "driving [your] usual lines and brake points on a track [you] know very well" but you're missing the queues that something is amiss - tire lockup, yaw/rotation, etc. It's all there, even with the inexpensive gear, it just takes a bit more time to figure out how to tune in.
The tips above to turning up tire noise is a good one. Otherwise, it just takes a little time.
#6374
Thanks, I am using a - rather old - Logitech Momo Force Feedback wheel, from my Need4Speed days.
I am currently on a one monitor setup (wanted to try if iRacing works for me before pulling the trigger on an Oculus Rift). The PC should be powerful enough: Intel i7-6700 with 16 GB of DDR4 RAM and a Nvidia 970GTX card
Not sure I want to spend $1,800 on a Accuforce wheel. can you guys recommend something a little bit more for the "budget oriented"?
OK, looks like
a) I need to play with the FF settings
b) pump up the volume
c) I picked a bad, super twitchy car, so I guess I start with the base 2015 Miata, I tried the RUF but with 650+ hp and maybe twice as much torque as my car it's so insanely fast that it's not even remotely close to my ride.
OK, looks like
#6375
Start with the Miata, then try the spec ford, move your way up to the RUF track. Fanatec makes a nice mid-level wheel package and very nice pedals. Here is an article about Xbox one wheels (that work for PC) at different price points: http://perfectsimracer.com/best-xbox...-wheel-review/
