Performance Friction race pads (mid-engine application)
Old 06-22-2011, 11:59 AM
  #31
TRT41
TRT41's Avatar
my order is in.
Old 06-22-2011, 12:17 PM
  #32
Astroman
Astroman's Avatar
OK, here is the million dollar question:
How does PFC 06 front/01 rear compare to Pagid Yellow (29) front/Black rear on a 911 Carrera with tiny stock brakes? Similar torque/bite? Is the amount of heat transfer similar?
I'm currently using the Pagids but would love to return to PFC (used 97s for years). The Pagids are more expensive and the bedding procedure is a huge pain. But the Pagids do perform really well.
Old 06-22-2011, 02:37 PM
  #33
Carrera51
Carrera51's Avatar
Jack:
An 06 front 01 rear combination should work well because you would be getting a little more out of the rear brakes as you do when running the RS29 front, RS14 rear combination you currently use. However, The Pagid RS19 and 29 seem to transfer less heat to our little calipers than other pads.
Old 06-22-2011, 02:54 PM
  #34
TRT41
TRT41's Avatar
Originally Posted by Carrera51
Guys:
Due to popular demand we will be special ordering a large batch of PF 0738 in the 01 Compound. Give us a call if you have any questions.
When do you expect to be able to ship? I talked to Brian earlier but he did not know about when they would be shipping.
Old 06-22-2011, 03:50 PM
  #35
Astroman
Astroman's Avatar
Enough said. Thanks.
Quick Reply: Performance Friction race pads (mid-engine application)
