Parting 944 Racecar, Suspension and AOR/S2 Tranny
Heads up, parting a late offset 944 Race car.
The car was built 3 years ago but never competed. Parts will be available in the next few weeks.
PM or email me at samluke@sbcglobal.net if your interested.
Fabcar A arms with the Delrin bushings, stock 968 caster blocks if you need them. The end of the arms was ground back to clear big brakes/rotors. $900
Front Bilstein Turbo Cup shocks, springs and perches, $750
Front hubs, spindles and cross drilled rotors for an NA car (not S2 or Turbo) $250.
944 TurboS AOR, LSD/Cooler Transmission, with S2 ring and pinion. Freshened before install. $2,000. This is the best tranny available for an S2, NA or GT car.
Front 968 MO30 sway bar with Delrin Bushings $300
Rear 968 MO30 sway bar with spherical bearing drop links $200.
Ground control sleeves for converting front stock shocks to 2.5" race springs $75, I also have various new and used springs available $75/pair.
Thank you.
Hey Richard, lets talk about those Fabcar a-arms. I am interested.
PM your number and I will give you a call.
Regards, ...Scott
Regards, ...Scott
Updated with A ams with Racers Edge Camber Blocks and Fabcar Delrin bushings, plus 968 brake scoops.
https://rennlist.com/forums/944-turb...available.html
