DE Car 911 or Cayman S
Old 08-24-2010, 09:41 PM
  #31
BostonDMD
BostonDMD's Avatar
Originally Posted by mooty
wont change any more.
found something i like.
and that is.....????????
Old 08-24-2010, 10:36 PM
  #32
bobt993
bobt993's Avatar
front yes.
rear no.
Actually, it's been done. My friend's shop fabbed a Cayman with a 3.8ltr. Then had David Donohue and Penske help on the suspension tuning. What a cool project. It should be a magazine article.
Old 08-24-2010, 10:54 PM
  #33
chopperzz
chopperzz's Avatar
Originally Posted by quickxotica
I agree with M758 on this point. The 944's with their 16" wheels have a nice wide envelope of accessible slip angles to play in without getting hurt. Their weight distribution is very good, and they respond well to traditional inputs (i.e. no electronic nannies corrupting the interface). I would stick with the '44 for another couple/few years unless there is some unmentioned factor that is forcing the issue.
Compared to the '44, the 996 (and to some degree the Cayman) will have "sharper" handling at the limit (in part due to the low-profile 18" tires) that leaves less margin for error between hero and zero (even with all the nannies).
before spending a nickle on different car, cayman or 996, put a better driver in your 944 and find a new benchmark to strive for. If you are faster in your 944 than the local hotshoe, upgrade. If not, spend more money on seat time.
Old 08-24-2010, 10:57 PM
  #34
todinlaw
todinlaw's Avatar
a new interseries cay is about 100k
i have all the cars discussed in this thread.
if you want to stay stock. 996 and cayman s are tied.
if you want to mod and develop the car 996 is better. it can use a lot of GT3 parts. you can't beat factory engineering.
can you get a cay to work, yes. but you need money and time and patience. i have some money, little time, NO patience. after 3 cay s, i came back to rear engined cars.
TC Kline has developed a suspension kit for the Cay. I stopped by his shop to look at a 2010 S with direct injection. This car is fast he has put the time and effort into some suspension tuning and has a pretty fast setup. I had a 3 but if go back to a P car the 2010 or better with direct injections is the ticket same speed less cost.
Old 08-25-2010, 12:32 AM
  #35
car_slave
car_slave's Avatar
I was pondering the same thing. I thought the cay-s was very similar in handling to a 944, and therefore was the better choice based on a 2000-2 996 to a 2006-7 cay-s. Plus, I think the 996 looks boring.
Old 08-25-2010, 01:13 AM
  #36
Krokodil
Krokodil's Avatar
Originally Posted by Gary R.
Can't the Cayman use GT3 parts like control arms, etc. also?
Cayman can use GT3 control arms front and rear. GT3 sway bar in the front (needs Tarret or similar in rear). You could use GT3 uprights, calipers, etc in the front but it starts to add up.
Moton and JRZ offer race dampers. Quaife and Gaurd make TBD and LSD options.
Ran a 1:37.6 this past weekend at Laguna Seca on R6 so the car can be built to go fast (see avatar).
Cheers,
Old 08-25-2010, 01:47 AM
  #37
mooty
GT3 player par excellence
mooty's Avatar
Received 5,480 Likes on 2,269 Posts
yes, anything can be done.
i have even seen a 4L boxster that can eat up cup cars.
and there are tube framed cayman being built.
but given the same amount of money, it's easier and faster to build up a 996 or 997, just stuff it with cup car parts.
if money is not an issue, then you can make anything go fast.
Old 08-25-2010, 01:48 AM
  #38
mooty
mooty's Avatar
mainly b/c no one would buy it
Old 08-25-2010, 02:48 PM
  #39
George from MD
George from MD's Avatar
I strongly agree with that. And I didn't mean to imply that he should go out and buy an Interseries Cayman just that IMO the Cayman would be a better learning tool and has so much more potential than a 996. Sorry for the misunderstanding.
I drove a 944 (S2) for ten years before getting a 993. It was a superb learning tool then (besides being a lot of fun to drive) and still is.
Old 08-26-2010, 03:13 PM
  #40
1way2rock
1way2rock's Avatar
Default Thank You
Thank you to everyone who psoted for the infromation.
Old 08-28-2010, 07:26 PM
  #41
obsessedone
obsessedone's Avatar
I think it was: http://www.europeancarweb.com/featur...n_s/index.html
Old 08-28-2010, 07:42 PM
  #42
Nugget
Nugget's Avatar
This should just be your signature, mooty.
Old 08-28-2010, 11:40 PM
  #43
mooty
mooty's Avatar
hey, dont pick on me.
i am a slow learner. i try, i fail, i try again, eventually i see the tree in the forest. in the meantime, i am still lost right now.
Quick Reply: DE Car 911 or Cayman S
