Spec Boxster build cost?
#47
mmhhh, sounds interesting!
c.
#48
NASA Racer
So tires are the main cost - everything else seems negligible (after 5 track days including 3 race days the brake pedal is still firm (SRF), plenty of brake pad and no cracks in drilled rotors).
I had one alignment done after the build and it's still fine after those 5 days. These cars just don't seem nearly as sensitive to alignment as GT3, for example, so that reduces costs as well.
#50
#51
I assume here is a boxster spec control document -
http://www.nasaproracing.com/series/...ster/rules.pdf
I just wonder - what actual engine repairs/mods are allowed there? it says engine should be stock but it is kinda vague definition - say if one starts with old 2.5L engine it will need new rings, etc, so, can it be machined to increase displacement or what are exact rules of this?
Also, what are rules with upper mounts? iit says in 2010 camber plates are not allowed - so, does it treat standard GT3 monoball upper mounts as camber plates?
And as i understand, any spec boxster is essentially a 97-99 car with 2.5L engines? or is there an 'alternative' spec boxster class for 3.4L engines?
just curious, I never was into boxsters racing much, so, sorry for kinda lame questions.
#52
Spec Boxster is 97-99 2.5L cars. Engines can not be modified to increase displacement or modify intake or exhaust (headers back is open) but you can add oiling (separator) mods, underdrive pulley, Intermediate shaft mod, and an accusump should you so desire. All other Boxsters fit into the Stock classes unless they have been modified beyond those rules, then you move into GT. It's all about the rules, they are pretty clear on what is and is not allowed.
#53
#54
#55
If I were in charge of BSR I would push for the RA-1. Given your life of the R888 I would expect maybe double on RA-1 further cutting operating costs.
#57
When 944-spec ran R888's we could only get 12-14 HC from them. This was not good compared to the 20-30 from RA-1. So last year was a challenge on the R888. This year we are back on RA-1 and everyone is much happier.
Same experience, and results, in the spec miata crowd.
#58
Engines can and are rebuilt to stock specs. There is an allowance in the factory service manual for rebuild tolerances and that is what you must adhere to.
#59
PS. I`m asking because i am just pretty curious how in practice an old already drilled engine with 100K+ miles on it is capable to sustain real racing - when i was at university i had access to local racing team and they were pretty much redoing engines from scratch every other race, so, here we talk about using a very old beaten up 97-99 boxster with potentially already drilled cylinders - s0, it is essentially means complete engine rebuild after every 60-80 running hours? once drilled cylinders are not going to last long. or can they be easily depressed from a block and replaced with new ones? i do not think so... so, what does it cost actually, in reality for those spec boxsters to maintain the engine? what is its actual lifespan after each subsequent repair and when does that moment come when you need to replace it completely?
