How-to make a front splitter
Old 06-24-2010, 08:08 PM
Darren
Darren's Avatar
Default How-to make a front splitter
I keep wrecking my stock front splitter and it's not quite big enough anyway. I think I'm going to try to make one according to the article below out of plywood, fiberglass resin, and fiberglass woven mats.
Has anyone ever done one like this before? Any thoughts on doing it this way?
http://www.specialprojectsms.com/ind...?categoryID=30
Old 06-24-2010, 08:23 PM
Astroman
Astroman's Avatar
My splitter is cut from 1/4" plywood without the fiberglass. It works awesome. And a 4'x8' piece of plywood ($20) is enough to make 3 of 'em.
Cut the splitter into two pieces so that when (not if) it eventually rips off, you may only have to replace one side of it.
Old 06-24-2010, 08:32 PM
mark kibort
mark kibort's Avatar
i made mine from fender aluminum. that way, its already painted too.
Old 06-24-2010, 08:37 PM
Darren
Darren's Avatar
Awesome, how did you guys support the splitter? Looks like like Mark has some wires or something, difficult to see.
Old 06-24-2010, 08:49 PM
Astroman
Astroman's Avatar
Mine doesn't stick out far enough to require any support:
Old 06-24-2010, 11:42 PM
mikew968
mikew968's Avatar
ditto 1/4" plywood, mat and fiberglass. replaced the stock belly pan and used Loews turnbuckles to adjust and secure. there are better support rods made but theya are 50 bucks apeice!!
Old 06-24-2010, 11:55 PM
Land Jet
Land Jet's Avatar
Darren, I have been researching this as well. You can buy a 1/8" sheet of polycarbonate for about $120 and make more than one. The polycarbonate is light and strong, only drawback is it will have to be painted, or maybe not. I am going to a refrigerator store to get a large piece of cardboard from one of their boxes to make a template. For strength and rigidity I figure it will need to be screwed to fixed body members under the front of the undertray. The polycarbonate supplier has a computerized router to cut the pattern for about another $100, so the whole thing should be less than $250. If you make it yourself, less.
Old 06-25-2010, 12:05 AM
JackOlsen
JackOlsen's Avatar
Aluminum, and not pretty. But it all unbolts and fits in the car for the drive to the track:
Old 06-25-2010, 12:06 AM
Darren
Darren's Avatar
Black cars rock!
Old 06-25-2010, 12:08 AM
Darren
Darren's Avatar
How much force do you think is put on a splitter that size? Looks like it sticks out 4-5" or so....
Old 06-25-2010, 12:28 AM
joseph mitro
joseph mitro's Avatar
plywood is heavy.
use polyurethane foam in the big 4x8' sheets you get from Lowe's or Home Depot, cut it to shape, and then fiberglass over it. I've made a splitter like this....much more lightweight than plywood, and still very rigid if done correctly.
fiberglass resin will dissolve certain foams, so it's got to be polyurethane foam.
lots of BMW racers use DiBond or Alumalite. Also very lightweight and rigid.
Old 06-25-2010, 12:42 AM
Darren
Darren's Avatar
The blue stuff?
Old 06-25-2010, 12:43 AM
Darren
Darren's Avatar
Actually I guess that is polystyrene?
Old 06-25-2010, 04:22 AM
Greg Smith
Greg Smith's Avatar
A vote for alumalite/alumacorr here.
Old 06-25-2010, 05:15 AM
MPD47
The Carnage King
MPD47's Avatar
That's what I use, strong, relatively cheap (ok, compared to carbon, it's $104 retail for an 8x4ft sheet), and easy to work with.
Quick Reply: How-to make a front splitter
