Emergency egress issues with Cool Suit?
It just occurred to me... if you're using a cool suit, and you need to do an emergency exit of the car, you'll first have to undo the quick connects.
Has anyone had to do this in a real situation? Are the quick-disconnects just that? Do they really let go quickly when you press the button?
Or, in a real emergency, will the little tubes just tear apart. Obviously, if your car's on fire and your life's at stake, who cares if you destroy a $140 shirt...
I have not tried to rip mine apart, but I'm guessing that if I had to it would not be a problem. My tubes are 8 feet, which allows me to exit the car before having to disconnect them, so that is one less thing to undo before heading out the door.
NASA Racer
You can buy quick disconnects that just pull out. You don't even need to touch them.
I had a real world situation where I felt there was the possibility of fire in my car from a gas leak and I got out of the car then disconnected them (didn't have the quick disconnects)
they do disconnect quickly, but the tabs are fairly small which would be a problem with limited visability and time . you'll have to practice release by feel, my hoses sare long enought to get out of the cabin
I can tell you from experience that the disconnects on the FAST version will tear apart without extreme effort and will not hinder the exit. A good sold tug will pull the fittings apart. I didn't do it in a fire but simply forgot to disconnect once when in a hurry to get out of the car and do tire temps. I now carry spare connectors in case I break them.
Do you stop to undo your radio as well? Drink tube? Same thing.
Coolsuit connectors aren't going to hold you in a car when there's a fire blazing. They'll pull apart one way or another. Adding them to your "routine" of getting out of the car in order to "save" your cool suit shirt would be wasting precious seconds that you don't have.
If you use the safety pull connector kit, the lines will disconnect and not break. No manual disconnect needed.
ApexPerformance.net
Premier Racing Outfitters
Toll free: 866-505-2739
Direct: 843-299-0997
EM: info@apexperformance.net
www.apexperformance.net
Save 10% on your next order over $75 on most items- enter Promocode Rennlist on your next order or mention Rennlist during your phone order.
Visit us on Facebook
ApexPerformance.net
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
I'm with Brian, they won't cause me one millisecond of pause in an emergency exit.
