PSS9 blue plastic cap and set screw
Does any else here have trouble removing the blue plastic cap intended to cover the adjustment dial on the underside of the shock? I had a heck of a time getting that b-stard off of there (adjusted them earlier today).
Also, on two of them, once I got the cap off, I noticed that the dial was in the cap (it had come off of the stem). As I look at the dial, there is only a small set screw in the side of the dial that holds the dial on the stem!
I thought the cap was there to keep the adjustment dial clean - but it appears it also holds the dial on as well!!
What kind of design is this? Has anyone else on here been frustrated by this? the adjustment stem doesn't even have a ridge or hole for the set screw to plant into - just tightness and friction hold it together...
I would appreciate a comment from anyone on here who has had PSS9's for a length of time, and adjusts them occasionally. (I do to switch from stiff for track, and full soft for road). Do you leave the cap on or off? Have you ever lost a dial? Do you guys just never adjust them?
Thanks!!
Thanks!!
Leave the blue cap off. It is a real pain in the @$$ to get off and not necessary. Haven't lost a dial yet but I know others that have. Its also counterintuitive that 1 is the stiffest setting and 9 is the softest. Why??
I could never get that 'feel' with the blue condoms on. And leaving them on can lead to a different set of problems. If it is not seated well on the - ehem! - the stem, it can act as a - umm... a reservoir, for - uh.... fluids. Yep, it can act as a reservoir for fluids to accumulate and rust out the dial. (No, really! That's not just a play on words!).
I'm not sure how the rear springs work on a coupe, but when I had them on my cabriolet, the dials on the rear springs had to accessed from the top, through a gap in the partially closed soft top mechanism. Those didn't even come with the blue caps.
