Toyota truck
#31
Forgot,
NHTSA Towing Guide http://primotrailersales.com/Towing_Tips.pdf
2008 Trailer Life towing guide http://www.trailerlife.com/images/di...wGuide0801.pdf
#32
I'll look at my book when the wife gets home. She drives it half the time.
#33
I have a 2007 Tundra, and pull a 24 ft Pace enclosed with a GT3. Trailer loaded weighs about #9500. I use a weight distributing hitch and have about #900-950 tongue weight. I put on helper springs. I have never had a problem, even taking the back ( very steep hills) way into Watkins Glen. It has never even gotten warm. I've never had any sway. It pulls absolutely straight, even in the wind. The tranny cooler does its job. I have gotten between 9 and 11 mpg, but it is reg gas. It is extremely comfortable and quiet, much better ride than the bigger trucks mentioned. I think that next time I'll get a diesel, but that is only because, like most of the people on this string, bigger is better. But to me, this is easily good enough.
#34
I have had 2 F350's which were total disasters. Both were expertly maintained and well cared for but gave me nothing but fits. My Dodge 3500 Cummins Mega-Cab is the best towing and most reliable truck we have ever owned. We tow race cars as well as horse trailers and it is not uncommon for the truck to be towing 12-13,000 pounds. Cummins engine never breaks a sweat.
#35
I have a 2009 Toyota Seq, 5.7L, tow capacity 9600 lbs. Pull a 22 ft ATC with a RSA, three sets of spare wheels/tires, generator, compressor, tools, etc. Has 5.5 dual axels. Found a chart that gave safe trailer size for tow vehicle wheel base length - that's why the 22ft. Use a Reese straight line hitch. Tow through the Cascades, and over the passes into Cali. No problems at all. 3500 diesel might be better, but I have no complaints.
#36
When I was looking for our next Heavy P/U that would see alot of towing I went with the Ford primarily because at that point it was the only one with the Tow Command feature which features an integrated brake controller that is tied to the ABS. It is the best thing since sliced bread. I understand that other makes now have similar options.
#37
I don't know what rear end it has. It is the 6 speed allison transmission though. When towing, I run it in the tow mode which I think is probably 5th gear. If I ran it not in tow mode, I'd probably do better towing but I don't want to harm the transmission. Plus I like the way the transmission downshifts under braking or going down hills while in tow mode.
#38
I really like the Toyota 5.7 liter platform. And it is built in Texas by Texans, so you KNOW it is good!
That said, while all you shamma lamma ding dongs are salivating over diesels, there is another choice:
Ford F250 or F350 with the 6.8 liter V-10 gas motor. It's a list price upcharge of like $600 versus the $6,500 for the diesel. And it really hauls.
Professional Racing and Driving Coach
#40
The new Tundra will be perfect for your needs. The older ones are in no way comparable, they are mini-trucks. The 5.7L motor is stout and the 6spd trans very nice. It is certainly the best value in the 1/2 ton market, IMHO, and that is why I got one. Mine was under $30k new. If you are dropping $40k, a diesel will be a better value.
My only complaint with my truck is the small gas tank. 26 gallons. I do get 20mpg highway though. Not bad for nearly 400hp and a 4.3 rearend
#42
Super Moderator
Needs More Cowbell
Needs More Cowbell
Except you'll be stopping every 30 minutes to fill up, which tends to annoy others that you may be towing with who happen to have diesels.
#43
The Shamwow RULES, irrespective of the drug-addicted *****-beater who shills it.
You are incorrect about the V10's fuel economy. The REALITY is that, with the new diesel emission equipment, diesel fuel economy on new vehicles SUCKS, and you've gotta ttake a leak into your urea tank every coupple of hundred miles as well. The V10 actually gets comparable fuel economy towing as a brand new Ford twin turbo diesel....and 1/10th the acquisition cost + no peeing.
3110, 410, carrying, distributing, distribution, end, featherlite, hitch, rear, towing, toyota, weight
