Looking for well built cage pictures - 944
Old 09-30-2009, 12:19 PM
  #31
M758
M758's Avatar
Originally Posted by jaje
In the end I'm far happier I went ahead and had a custom cage built to fit my tall frame (or as Karl says "larger frame") and have more confidence pushing the limit. It gave me several inches more clearance and I now have a knee bar that is underneath the dash and not directly touching my shins / knees.
Autopower cages fit normal sized people. If you are very tall or short it just won't fit as well a custom job. This is not a fault of the autopower cage, but just a reality when trying one size fits all.
Old 09-30-2009, 12:48 PM
  #32
glhracing
glhracing's Avatar
Here is my cage. FIA spec.
Old 09-30-2009, 01:18 PM
  #33
DanR
DanR's Avatar
^ great looking cage, who made it? Just my $0.02, I would really want a halo seat with the triangulation bar next to your head (foam helps but only a bit!)
Old 09-30-2009, 02:01 PM
  #34
RedlineMan
RedlineMan's Avatar
Originally Posted by RedlineMan
I always put the header tube IN FRONT of the exisiting roof header, ESPECIALLY if the driver is short. You are looking for more space there (head clearance), so putting your header tube behind the roof header would be dumb.
Originally Posted by stownsen914
RedlineMan -- Can you elaborate? I'm not picturing this ... thanks.
'77 930
'86 944T
My '84 944. Dual 1.5 tubes instead of single 1.75 takes less space but increases strength.
Old 09-30-2009, 02:03 PM
  #35
RedlineMan
RedlineMan's Avatar
Originally Posted by smlporsche
John-
I was hoping you'd chime in as I know you have done many of these. I'd like to see some pics of your work if possible.
http://redlinerennsport.homestead.com/CagePage.html
Old 09-30-2009, 02:07 PM
  #36
RedlineMan
RedlineMan's Avatar
Originally Posted by Lemming
John, notice how the front a-pillar bar goes to the
floor pan but is also welded to the side plate. I've not seen this on other
builds, what are you thoughts?
Hmmm...
The 944 sill is narrow, but not THAT narrow. I never really considered it, and
I'm not sure why it was done, but I guess it works. 6-of-one, half-dozen-of-the-
other.
Lots of base plating needed. More profits!
Old 09-30-2009, 02:14 PM
  #37
Charles A. Toupin
Charles A. Toupin's Avatar
^ Great cage!
Here is mine. I already hear some of you say that the nascar bars are too high, but it's fine with me. Plus I have lots of clearance on the left side. It's also welded to the rocker panels, roof, A and B pillars, some other places on the unibody and firewall. There is a bar that goes behind the dash too... Probably an overkill cage...
Old 10-01-2009, 12:05 PM
  #38
glhracing
glhracing's Avatar
It was Built by Bill Doyle in Lynn Mass. http://cagethis.com/
the roof bars are a little close. I originally wanted halo seats, but with the door opening being so narrow, i cant get in and out of the car with them. Standard seats will have to do.
-Brian
Old 10-01-2009, 12:51 PM
  #39
RedlineMan
RedlineMan's Avatar
Is that for racing... or jumping the Grand Canyon?
Old 10-02-2009, 10:12 AM
  #40
glhracing
glhracing's Avatar
I like to be prepared just in case.
Actually i also am going to run some hillclimb events on mountain roads with trees and rocks which hurt a lot more than tire walls. Plus i come from a Rally background and dont always feel safe without a proper cage.
a few extra pounds into a good cage is well worth the cost in weight added to the car.
Old 12-05-2009, 09:52 PM
  #41
95ONE
95ONE's Avatar
LOL. I thought the same thing when I saw his pics. A bit more than a few extra pounds, but...... seriously. Its a life saving device, so I don't knock the over built cages too much... I don't prefer one. But never would I knock it more than a nudge and a wink.
Mine is almost done. Welding in the pedal cluster before I weld in the Door bars. Ingress and egress for fitment of pedals will be much easier If I just wait a little.
Old 12-06-2009, 04:36 PM
  #42
333pg333
333pg333's Avatar
What do we think about the difference between the A pillar bar coming down in front of the dash vs going through the dash? I am inclined to go for through the dash option. Just looks like you get a bit more room.
Any thoughts?
Old 12-06-2009, 04:44 PM
  #43
DanR
DanR's Avatar
through the dash is better IMHO however when I looked at doing that there was no was of getting the dash bar behind the dash with the dash cluster and heater etc still in place which they need to be for stock race classes. I therefor went for infront of dash with a dash bar
Old 12-06-2009, 06:14 PM
  #44
smlporsche
smlporsche's Avatar
Through the dash is much better.
That's why I started this thread as I wanted to re-do the front part of my cage and the door bars and was looking for some good designs to show a builder.
Old 12-07-2009, 12:40 AM
  #45
comatb
comatb's Avatar
Dan, what is the bracket on the steering column with the two red button for. If it's for a radio why two?
Bill
Quick Reply: Looking for well built cage pictures - 944
