HOOSIERS ON THE STREET???
I am in the position of having to drive my car to the track with R6s on. I had lined up a spare set of wheels but they don't fit.
As these are DOT and seem no softer than other R spec tyres is this really going to harm them? We don't get the tyres
to heat on the road to and from the track anyway? Am I missing anything else?
It's not what I wanted to do but now I've run out of time.
Ok, thanks.
Two risks. First is road hazard damage do to the lightweight construction. Second is encountering standing water if it rains. I have seen many people do it for short road distances.
Not worried about the rain as we have decent weather at the moment, but the damage is a bit of a worry. Guess I'll have to risk it and avoid potholes!
The R-6s can be driven on the road but as stated they are pot hole sensitive and any type of dampness on the road and you are going to be a passenger.
I had a similar situation where I had no other alternative... An hour-long drive on interstate highways, and no appreciable tread wear. Since I rarely get R6's down to the cords, that left only heat cycles as an issue. (I did count both directions as a heat cycle).
I imagine that R6's on mostly surface streets of varying quality could make tread wear a bigger factor.
So how does "DOT" translate down under? I assume they street legal?
Damn, for a minute there, I thought this thread was called HOOKERS ON THE STREET...
Besides water, the biggest risk IMO is that tires like the R6 are a lot more easily punctured by the errant debris and roofer's nail one regularly runs over on public roads. Normal street tires can shrug a lot of this debris off. Slicks like R6's, KumHoe 710's, and Hankook Z214's cannot.
Professional Racing and Driving Coach
My local track is ~60 miles on a fairly smooth country road. I drive there on R6s on a regular basis. +1 on what everyone said about water and about punctures. No ill effects on their longevity or stickyness. I don't think driving the R6s going straight gets them up to temp to count as a heat cycle (I could be wrong on this).
when i drove to LA to get my car shipped to road america, (500 miles to 911Design in Ontario) i got gas about half way down. since it was about 90F outside, i decided to check temps. temps were just about 160F. 5 hours on the scrub toyos didnt seem to hurt them much. OR the way home. I do think if they were hoosiers at the time, that would have been a heat cycle.
I guess it depends how long you run up to temp. I forgot what tirerack bakes the tires at, but if its 30min at 160F+, I think I might call that a heat cycle.
Ive been driving to the races for 10 years now on Hoosiers and toyos and havent had a problem, with punctures or anything else. on the Holbert car, thats over 25,000miles alone, all on DOT rubber.
Find a reeeeeal cheap set of rims/tires to get there on. You may get there (BTW soft r-tires can pick lots of crap on the road which is annoying), but if you cord an R6 at the track you still need to get home.
