Safety devices install kit
I am looking for a 944 Safety devices install kit for their 6 point bolt in cage. I only really need the front leg plates as I can easily fabricate the rear ones. Anyone know a supplier?
stable energies is who you need to talk to they'll take care of you. Word of caution, if you will be racing NASA the main hoop will need an additional diagonal, and for both NASA and SCCA you will have to add an additional door bar(s)...
been delayed with in due to work but so far have now stripped the old car, pick up the new tub next Saturday and drop it off at the garage the same day for the drivetrain swap. It should be back on the track by the end of July which suits me as I cant really get out until then anyway. Planning on Thunderbolt and then Summit race so we will she how she runs.
I am actually changing to a better Leda double adjustable suspension and getting solid bushings rather than drelin so should be a better car as well. Will be running is uncompetetively in G for the rest of the year then this winter it is going in for a sunroof delete, manual steering rack, change the R&P and the 993TT brakes back to original etc and will run it as a turbo cup next year. -230lbs should help
PS - can I return your whinch next weekend? (cheers again)
