Longshot: Can Hankook RS2 tires be run backward in the dry?
Old 04-30-2009, 04:03 PM
ew928
Owns the Streets
Needs Camber
ew928's Avatar
Originally Posted by Glen
He can run backwards in the rain....
Then will they dump his front-engined 944 in that other class of cars?
Old 04-30-2009, 04:16 PM
Potomac-Greg
Potomac-Greg's Avatar
Originally Posted by ew928
With the 4 longitudinal grooves, I wonder if the sipes and the outer angled tread blocks will pump much water into the contact patch in the rain if run backwards.
Hankook finally makes the RS2 in a size I can use, might have to try them for the street.
I have two track days on them and I'm very happy. I sold my Toyo RA-1s (which were also wider) and I was pleasantly surprised by how close the RS2 is to an R compound. One caveat -- I had mine shaved down to 5/32s. A full tread tire would probably squirm more.
Old 04-30-2009, 05:28 PM
kurt M
Mr. Excitement
kurt M's Avatar
been there done that got the speed stripes to show for it. Twice in one 30 min session, figured I better hang out in the paddock for a while and went in OPR . Another time was down the chute at SP in the right seat of a 931 from the kink almost to T5. Found out that I do not like not having my own wheel and pedals to jerk and stab at when things go wrong.
I was talking to a local tire rep and he was saying that few if any tire makers are making the carcase directional. The tread and water removal is the key. I bet there are some tires that are developed for very tight use profiles that are more than water directional.
Old 05-05-2009, 06:21 PM
Potomac-Greg
Surprising reply received today from Hankook Motorsports:
Thanks for your inquiry.
As for running the R-s2 in reverse, we do not recommend this, especially at high speeds.
There isn’t any verification numbers on this kind of use to assist or confirm your kind of use.
Sorry we couldn’t help you more on this issue.
Good luck in your endeavors.
Motorsports Group.
Old 05-06-2009, 12:58 AM
Lemming
Lemming's Avatar
They are just covering their butts and want you to kill tires and buy new ones.
Old 05-06-2009, 01:35 AM
ritzblitz
ritzblitz's Avatar
Indeed, hopefully that's the case!
Quick Reply: Longshot: Can Hankook RS2 tires be run backward in the dry?
