Advice on wheel heat issue
Old 03-03-2009, 03:49 AM
sundog
Workin' It, Daddy!
sundog's Avatar
Default Advice on wheel heat issue
During my last DE at Thunderhill, my 964 rear wheels got so hot that the wheel balancing weights melted off the wheels. The tape holding them on, not the lead itself. Also, there was a significant amount of axle cv grease coming out of a small hole in the center of the axle into the wheel hub (outer).
I'm running with the brake dust shields, and have upgraded the rear brakes to the 993 calipers, same sizes as the late model 964, and have the correct bias valve. Also, just porsche OEM pads.
Any advice would be greatly appreciated.
sundog is offline
Old 03-03-2009, 08:57 AM
Geoffrey
Super User
Geoffrey's Avatar
I would have a look at your drive axle assembly. Once the grease begins to push out the center vent hole, it has been compromized and turned into more of a liquid than a paste. If you continue to run, your CV joint will fail.
Use aluminum tape on the wheel weights to keep them on. This is common practice with track wheels and weights.
Geoffrey is offline
Old 03-03-2009, 09:16 AM
Veloce Raptor
Torque Monster
Small Business Sponsor
Veloce Raptor's Avatar
Also consider removing the dust shields IMO.
Professional Racing and Driving Coach
Veloce Raptor is offline
Old 03-03-2009, 09:51 AM
onefastviking
onefastviking's Avatar
Do you have an early 964 with the small single piston rear caliper ? If so consider replacing to the later style.
Also, are you possibly braking too hard ? Too much ?
onefastviking is offline
Old 03-03-2009, 10:40 AM
Jarez Mifkin
Jarez Mifkin's Avatar
+1
CV joint failure's in the form of grease ejaculation cause the brake rotor to be deemed worthless and can/will cause an unsafe situation.
Jarez Mifkin is offline
Old 03-03-2009, 12:06 PM
sundog
Workin' It, Daddy!
sundog's Avatar
Thanks for the advice Geoffrey. I'm ordering a new boot kit from EBS racing, and will also get some of the Neo Grease. Aluminum tape, what a great idea!
sundog is offline
sundog
Workin' It, Daddy!
sundog's Avatar
That is on the list for the next DE in late March. Hopefully keep them cooler.
sundog is offline
Old 03-03-2009, 12:08 PM
sundog
Workin' It, Daddy!
sundog's Avatar
I had that setup, but replaced them with 993 calipers with the 2 piston rears. They are the same as the stock 92-94 964 rears, but cheaper.
Braking too much, I don't know. My instructors kept yelling, brake, Brake, BRAKE BRAKE! So maybe not?
sundog is offline
Old 03-03-2009, 12:09 PM
sundog
Workin' It, Daddy!
sundog's Avatar
Originally Posted by Jarez Mifkin View Post
+1
Oh, that's not good to hear. I've already got a list as long as my arm of things to do before the DE. Is it a warping issue, or a glazing issue? Can I visually check them?
sundog is offline
Old 03-03-2009, 12:11 PM
Geoffrey
Super User
Geoffrey's Avatar
It is the outside joint that is probably the problem, and they are not designed to be replaced.
Geoffrey is offline
Old 03-03-2009, 12:19 PM
sundog
Workin' It, Daddy!
sundog's Avatar
Yes, I searched and found the thread about you rebuilding the CV joint. I don't have the access to the machine tools yet, and it's a Tiptronic for now, so the axles are different. I can probably get one from Parts Heaven if it's shot though.
sundog is offline
Old 03-03-2009, 01:08 PM
JackOlsen
Super User
JackOlsen's Avatar
What pads are you using? Did you experience brake fade? If you did, what brake fluid are you running and when were the brakes last bled?
Another possibility is a sticking caliper.
Thunderhill is not easy on brakes, but I doubt your problems are from your wheels getting too hot.
JackOlsen is offline
Old 03-03-2009, 01:14 PM
sundog
Workin' It, Daddy!
sundog's Avatar
I'm using stock OEM pads. Will replace them after the next DE. Or maybe I should do it now.
No brake fade, using ATE Blue, bled right before the DE.
Calipers have less than 2K miles on them. Still a possibility of them sticking?
sundog is offline
Old 03-03-2009, 01:25 PM
JackOlsen
Super User
JackOlsen's Avatar
If they're sticking, you'd likely be able to see hotter-than-normal temps in street driving, too.
My guess is a cracked and/or leaking CV boot -- and that the weights fell off for no particular reason other than that wheel weights sometimes come off.
Old 03-03-2009, 02:18 PM
RedlineMan
RedlineMan's Avatar
Hey;
I would first want to determine where the heat is coming from. If it is the brakes, then I would get those dust shields off, and I would strongly suggest new pads. Factory pads often create excess heat because they simply do not have the bite of a real track pad. When you have increased friction coeficient, you find that you have to brake with less force. The increased efficiency of the performance pads often leads to lower temperatures.
Inner CV joints often get most of their heat from the engine/transmission itself, and lower amounts of air flow, and often are the first to fail for this reason. The wheels are likely getting their heat from the brakes, and that amount of heat certainly won't help the joint grease (or any other component) on either end. Do yourself a favor and use a really good grease like Krytox or Neo when you service the joints. It will hold up much better than other more generic lubes.
I'd also wonder about the rear axle bearings if it is all getting that hot.
RedlineMan is offline
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
