Torque or HP on the road course????? Which is better?
Old 02-04-2009, 10:47 PM
  #31
Veloce Raptor
Veloce Raptor's Avatar
Originally Posted by A.Wayne View Post
He would get lapped
Yeah....and then there is REALITY.
Veloce Raptor is online now
Old 02-04-2009, 10:48 PM
  #32
Veloce Raptor
Originally Posted by Van View Post
Sounds like torque sells... and HP wins races.
Hm. Not quite. LOL!
Old 02-04-2009, 10:49 PM
  #33
JoeMag
JoeMag's Avatar
Mark -- I have seen several charts using thrust (lbs of thrust) to determine when to shift gears. These are the ones that show thrust in each gear. These calculations use torque, wheel dia, gear ratio and final drive ratio to calculate thrust. How does that compare to what you're saying above?
JoeMag is offline
  #34
Veloce Raptor
Originally Posted by mark kibort View Post
I have a short attention span too, so I know those 4 paragraphs were like reading a book for some. Ok, lets just say there are a couple pre-emptive paragraphs to fight off the inevitable questions that usually follow in the beginning of such discussions.
in a nut shell:
Hp at any vehicle speed determines rear wheel torque, and thus all accelerative forces. This is regardless of engine torque and engine rpm.
one example:
two cars coming off a turn in the meat of their 2nd gear, if both cars are at 350rwhp going to 400rwhp midway down the straight, one could be going from 4000rpm to 6000rpm and the other from 5300rpm to 8000rpm and both could have the exact same rear wheel torque, meaning both would have the exact same accelerative forces. (meaning: if one had 400ft-lbs peak torque and the other 275ft-lbs, their would be no difference between the performance of the two)
mk
Mark, you are still prattling gibberish.
Same weight, same car, the car with more torque at that moment will get out of the corners faster and win the race. It is as simple as that.
Old 02-04-2009, 10:51 PM
  #35
Veloce Raptor
Yep !
Barky Dave is an Idiot ...
about right champ ! not the peaky stuff ..........well dat's what the Finn told me
Yeah...and then there is reality. It's nice to see how much I am under your skin, though, as I repeatedly illustrate your bottomless ignorance here.
  #36
Veloce Raptor
Originally Posted by gbaker View Post
Torque is the current fashion statement. Too bad it doesn't make cars go faster.
But it gets them out of corners faster, which is what you need on a technical road course....which was the question in the OP.
Two cars with 400 hp, same weight same handling, give me the one with the higher torque any day. Which is exactly what the OP asked, irrespective of Wayne's ignorant drunk posting.
Old 02-04-2009, 10:52 PM
  #37
KurtC
User
Check this out, interesting read.
http://www.boostaholic.com/hptq.html
KurtC is offline
Old 02-04-2009, 10:55 PM
  #38
A.Wayne
Formula One Spin Doctor
A.Wayne's Avatar
A fifty year old TS talking Gibberish You go girl .........................
A.Wayne is offline
Old 02-04-2009, 10:57 PM
  #39
Veloce Raptor
Sorry the truth hurts, queen bee. Oh, and I am not 50, and won't be for a while. So as usual you are batting 0.000.
Now keep asking How High every time I tell you to jump, loser.
Old 02-04-2009, 11:02 PM
  #40
NJ-GT
Mark, that's a great explanation.
For the non believers, take your car out, most cars these days have a very flat torque curve. Put the car in 4th gear at 30 mph and floor it, later do the same with the car in 2nd gear, compare acceleration by butt feeling or plug a G-Tech/Pro, Traqmate, Vbox, etc.
Look at the 335i BMW torque curve, quite flat. However the car produces 120 Hp at 2,200 rpm, and with less torque it produces 285 Hp at 5,600 rpm. Which car is quicker, the one with 120 HP or the one with 285 Hp.
Bottom line, the idea is to maximize horsepower to the ground at any given vehicle speed, this is a combination of gearing matching the power curve.
NJ-GT is offline
Old 02-04-2009, 11:20 PM
  #41
DanR
Super User
He would get lapped
The only way to prove this is for you girls to duke it out on the track for real rather than talk smack!!!!! (I know who my money is on ...............cough VR)
DanR is offline
Old 02-04-2009, 11:22 PM
  #42
Veloce Raptor
Originally Posted by DanR View Post
He would get lapped
It would be a real treat.
Old 02-04-2009, 11:26 PM
  #43
A.Wayne
A.Wayne's Avatar
He would get lapped
..........Cough ........................................You would lose ..............
Projecting again numbnut .....
A.Wayne is offline
Old 02-04-2009, 11:31 PM
  #44
Veloce Raptor
You sound a lot like another all hat no cattle toolbox named Frank Lin AKA GhettoRacer.
Enjoy your delusions of adequacy, Tweedle Dumber.
Old 02-04-2009, 11:35 PM
  #45
onefastviking
onefastviking's Avatar
This question and debate is so tempting to jump in on, but I think I will keep it simple.
It is an airpump.
Horsepower and Torque are related, with RPM in the equation. - It's a simple equation.
Efficency is king.
Gears, whether trans or rearend/diff can/will multiply effect.
While those statements should clear things up they will probably just muddy it worse for most.
onefastviking is offline
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
