2008 SIngapore GP , News ,Updates, Results..
#106
Owns the Streets
Needs Camber
Needs Camber
Team to Massa after the race.
Felipe, didn't you get the memo. We changed the pit lighting system last night.
Red is stop. Green is get ready to go. Not go.
Wait for the purple light to come on before you can safely leave the pits.
Heard one of the TV commentators say that the Fueler triggers the Green light on the Ferrari system.
Is that correct. Isn't the fueler's job to safely remove the nozzle for the race car?
Not look around to see if the pit travel lane is free so the Ferrari can be released to a clear lane.
#107
personally, I think blinking colored lights belong on a christmas tree, not in the pits of F1.
what's wrong with a plain old lollipop again? (noticed Ferrari switched to that for the remaining stops)
#108
King of Cool
...Heard one of the TV commentators say that the Fueler triggers the Green light on the Ferrari system.
Besides, in this case, the fuel guy wasn't even trying to take out the hose when the light turned green.
This is the same as Williams' hydraulic jacks, technology for no real benefit and just an added element that can fail.
(although Williams' jacks have never failed and Ferrari's problem is still the human screwing up)
#109
Owns the Streets
Needs Camber
Needs Camber
Their Magnetti Marelli lollypops were failing?
Good to hear the fueler isn't the trigger guy.
So who was the brain dead Ferrari pitman manning the Christmas Tree lights.
#110
Formula One Spin Doctor
... am I the only one who doesn't find that a terribly attractive back-end? maybe its the ATOMIC WEGGIE or the cellulite-wrinkles or the muffin-top or ...
#112
I was VERY impressed with Rosberg. He maximized every segment of the race and it all came good. When he had to pit during the SC and incur the penalty, I thought it was over for him. But he buckled down and took full advantage of his ability to run in clean air to make a useful cushion. Great example of a driver “making” his luck. . .Maybe it was not unintentional bias, but it does illustrate the inconsistency that we often see in application of the rules.
Why did it take so long for race control to issue the penalty to Rosberg? Not only that but with the 3 lap rule he was able to make the penalty really no penalty at all. Though it was good to see him make the best of the situation I believe race control "made his luck" for him!
#114
You gave the very best example of that inconsistency with your observation of Rosberg.
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
#115
Actually, I don’t think it was inconsistent, at least in the way the regulations are written. The stewards reviewed the reports and issued the penalties for Rosberg and Kubica at the same time, shortly after the SC period ended. Rosberg came in within the allowable interval, as specified in the rules. I don’t really see how it should have gone differently. Yes, Rosberg was very fortunate to be able to use clear air, but that was not a result of inconsistent rule application, but rather good luck at how it all fell out. Essentially the rules allow that element of variability. Inconsistent would have been if Rosberg was given any sort of a different penalty than the rules call for in that situation, or if the rules had been administered differently than normal, which I believe was not the case.
I would agree if your point was that the current rules surrounding these penalties do not take into account precise circumstances that the subject driver is encountering and thus, the actual severity of the penalty will vary. For that reason, grid penalties for the next race may be a more “standardized” way of enforcing a penalty, however what do you do if it is the last race of the season!!
#116
Great weekend for FA. I hope he stays at Renault and turns the team around again.
#117
Yeah, ambitions my ***... disastrous singapore gp??? how about a freaking disastrous season! From australia to singapore it's been pitiful to watch on all fronts. Between freak technical failures(Ferrari had been reliable for a long time...), drivers mistakes, strategic mistakes and pretty much every blunder you can make in F1 they still "believe their WC ambitions are still alive" ... Just sad.
#118
disastrous singapore gp??? how about a freaking disastrous season! From australia to singapore it's been pitiful to watch on all fronts. Between freak technical failures(ferrari was once reliable...), drivers mistakes strategic mistakes and pretty much every blunder you can make in F1... How to throw away a WDC and WCC.
#119
#120
