Video Camera Mount - Not Rollbar *Help
Guys,
I've searched and am trying to figure out how to mount my video camera so it is within reach of me in the driver's seat. I have a bullet camera that will be setup and I was hoping to find an easy way to mount the camera to the passenger side of the center console.
My plan was to find a plastic container that I could cut up, fill with some foam lining, and leave the top (small side) open so I could easily drop the camera into the box as I'm leaving pit out after hitting the record button.
I have not been successful in finding the right kind of box and was hoping that this community could direct me to a plastic box. I have the Aiptek camera, so the box doesn't need to be very large - ANY IDEAS?
If anyone has a better mounting idea I am all for hearing it. Pictures are even more helpful.
Wow me with your creativity...
THanks
THanks
Can you reach your glovebox? A solid block of foam (i.e. 6-8" thick stiff seat cushion from an upholstery shop) with a cutout a bit smaller than your DVR camera will hold it and help with shocks.
Skip - when I used a DVR camera with a bullet cam in my glovebox I used the remote to turn it on/off. The remote was small and velcroed to my radio delete plate. I use the same velcro for my new Aiptek. Bitch is you can't see a "Record indicator". A small aluminum box bolted to the floor on rubber mounts would work well for you, have one welded up!
Mr. Excitement
Between the seats. Run a web strap through the plastic box and around a seat base, lap belt buckel base or other sutable mount. Set it up so the strap keeps the recorder from being able to come loose.
Mr. Excitement
I am going to use the Aiptek 1080 camera, but want to be able to reach it from the seat for turning it on and off. This has been the biggest complaint for video recording I have.
Kurt - thanks for the ideas.
-Skip
-Skip
Mr. Excitement
A bullet cam can be mounted in a lot of ways from hard mounts to racertape. Most groups require even small recorders still need to be held tight in proper mounts to prevent them from becoming projectiles in a wreck. Some groups ban suction cup mounts for recorders but not cams.
as camcorders get smaller and lighter I hope the rules will flex to take this into account.
I had a similar need... no rollbar. Thought about suction mounts, but the rear window of the soft top is too flimsy, and I didn't want that big of an obstruction on the windshield in front of me.
My DIY Solution:
1) Removed rear seat backs (I did this separately when my kids outgrew the back seats, but it's a prerequisite to this approach).
2) Bolted two "L" shaped pipes together and then bolted each (at the "top" of the L) to the rear seat back mounting hardware (near the center, on either side of the transmission hump). Length of the "L" rests on the transmission hump, and the short ends of the L curve upwards and terminate at shoulder height just behind the front seat backs.
3) Bolted a tripod head to the end of one of the pipes. (can also do this for each pipe if I wanted to mount two cameras). Lots of ways to do this, but settled on reusing an old Rennline tow hook mount (the threaded side sticks out the top of the pipe, and holds the tripod head, the hook side - without the hook - is bolted inside the pipe about two inches deep).
BTW, for the pipes, I reused the parts of the wheeled hard-top carrier - they were the perfect sized "L", and had pre-drilled holes in all the right places to mount to the seatback hardware and handle the tow hook.
Total cost: just the time to figure it out and assemble. No new parts. (OK, a few bolts).
All I have to do is reach back about as far as it takes to scratch your ear to hit the on button. The top of the L can pivot on the rear seatback mounting hardware, so I can also place a variety of cushioned objects underneath the back of the "L" closer to the front of the car to prop the camera up to different heights. (a wheel chok works great). Total weight is enough to keep it from bouncing, but you can always secure with a ratcheting strap or bungee cord anchored to front seat mounting hardware.
Let me know if you want pics...
My DIY Solution:
