Hudson Valley Region WGI DE / Open Track Event October 15/16
#31
Moderator
I think it means they are still trying to figure out where to put the Unassigned... Must be on Double Secret Probation
Wow, 1/3 of the 32 registered are GT3s - should be interesting...
#35
wow this event sounds great i was planning on doing the riesentoter njmp thunderbolt event on oct. 17-19 .but this event may be to good to pass up,if i can get into the open track run group.by than,if i can get my smoothness a little better maybe i can get bumped from white to black.and than add another gt3 to the list.
#37
Just signed up for this event. 4 days at The Glen, Monday/Tuesday with Niagara, followed by these two days.
#38
Boston - it simply means, as has been stated by HVR guys, that because you are a White driver you need a check-out ride to run it the Open group. There will be more run time than you can stand after that and you will have 0 problem getting accepted, trust me...
#45
Thanks for your support........
