vir fun: screwup part deux
Can't really tell from the little info in the video, but Jazz must have had an exciting time following/passing you
Maybe I'm seeing and hearing things. I plugged in my headphones and jacked up the volume to watch it a few times. Here what I heard: after blipping the throttle, the RPMs sounded like they dropped way down. The first thing that comes to mind is that you forgot to let the clutch out! Or maybe you caught the wrong gear?
Hmmm...
Not the greatest timing on the downshift, I'd say. A bit late in order to take the corner with throttle on. I downshift in the left bend at the top of the hill. Otherwise, trailing throttle, turning in, and 911. Any other questions?
Next time I suggest you brung some adjustability! It is indeed true that you need to learn to drive in all conditions, but that's hard to do if your car is in a tiny little wad.
Sure sounds like you lifted a touch before the tail shifted. I can't see the tach, but there is a change in note right before. I think you made a really nice recovery.
