Tire Sizes
I run 8" and 9" Fikses without problem (see picture to the left ). I ordered them standard offset from Wheel Enhancement for the '86 911. I run 225/45/17 Hoosiers on the front and have fit the 245 Kumho V710's as well. However, if you have done suspension mods (big coilovers) you'll likely need to use a small spacer (4mm) on the hub.
If you have coil-overs, the limiting factor on ride-height will be the steering rack angle before it will be the size of tire.
