NEW HANS Device - Feed Back
I plan on getting a HANS device this year... Does anyone have any feedback on the new "starter model" that came out in January?
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
From one of the bigger dealers of HANS that I work with the new Sport Series will realistcally be available in Feb. Not too shocking since they aren't out yet and it's the 27th.
Saw it at PRI. When you pick it up it is noticeably heavier than the other 2 models. However it will be resting on your shoulders when you are driving so you won't notice it so much.
The 'wings' on the side are notably higher than the other versions.
Other than that it looks like any old HANS device.
Scott
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Those wings may be higher because of different materials used as well. I don't know. I am talking about the small vertical extensions.
They won't substitute for mounting the shoulder harnesses correctly though. I know people with early HANS devices with no wings, no friction material that have no problem with the belt staying on when they are properly mounted for a HANS device.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I'm sure every little bit helps. However when I walk through the paddock I see a large number of people who wear a HANS and their belts aren't mounted the way HANS reccomends.
I'll bet the higher vertical wings are a result of consumer pressure. If you have your setup correct, the belts won't slip off. But alot of drovers were complaining about belt slippage and since having vertical wings won't affect performance, they added them. I'll wager it's just marketing.
Super Moderator
Needs More Cowbell
Needs More Cowbell
It has been interesting to watch the design evolve over time (wings, no wings, back to wings, larger wings, 3" belts, 3"-2" HANS specific belts, back to 3" belts.....)
I don't think so. HANS is part of a complete safety package. You need a full containment seat with head-halo and side nets on both sides. That would keep the torso intact in an off axis impact.
Super Moderator
Needs More Cowbell
Needs More Cowbell
The HANS/shoulder belt interface, throughout all of its iterations, is fundamentally and fatally flawed. It is analogous to trying to hold something up by simply squeezing your hands together....there are limits to friction, cross sectional area, yadayada....
That having been said, the HANS is better than nothing.
