compression norms
compression norms
Another question from left field. I performed a leak down test and a cylinder compression test on my 3.4L watercooled motor today. Does anyone know what the compression numbers should be? I'm not looking for the compression ratio but the actual numbers you would see from a simple compression meter, ie PSI or kpa x 100. Thanks again for any input.
