Chassis Rake and it's effect on balance / handling
Old 01-18-2018, 07:22 PM
ProCoach
Basic Site Sponsor
ProCoach's Avatar
Received 2,793 Likes on 1,651 Posts
Originally Posted by Thundermoose
I'm gonna throw your comment on the M3 forum and see what other folks think. Maybe with the way we measure rake (top of fender to center of wheel) that 0.5 difference actually provides a positive body rake.
Hahaha! THAT'S what it is!
I'm measuring off jack points (furthest forward and furthest rear under the rocker panel pinch seam) to the ground or suspension pickup points to the ground.
If you measure where I measure, you'll get what I get, I'll bet.
IF the nose were truly up more than the back, that would screw up undercar aero all kinds of nasty ways. Center of pressure needs to be further forward, even on a non-aero car.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Old 01-18-2018, 07:29 PM
Thundermoose
Thundermoose's Avatar
Cool. I know your right. I have drive on 2x6 to be able to access front jack points with my big jack. Thanks.
Old 01-18-2018, 07:43 PM
ProCoach
Basic Site Sponsor
ProCoach's Avatar
Old 01-19-2018, 05:51 PM
audipwr1
audipwr1's Avatar
Look for the best balance and most go too low. Never seen negative rake (front higher than the back) on a well handling car, only to fix a major problem before you can fix it correctly.
Imsa caymans had this a few years back
Old 01-19-2018, 09:08 PM
ProCoach
Basic Site Sponsor
ProCoach's Avatar
Yep...
Old 01-19-2018, 09:18 PM
fatbillybob
fatbillybob's Avatar
A more interesting discussion would be "Why?" I'd like to hear more about the theory behind the set-up. I'm sure the unwashed masses will never hear it.
Old 01-19-2018, 09:20 PM
Frank 993 C4S
Frank 993 C4S's Avatar
Could have been BOP and set by IMSA.
Old 01-19-2018, 09:40 PM
fatbillybob
WTF BOP? I'm DUM
Old 01-19-2018, 10:18 PM
Frank 993 C4S
WTF BOP? I'm DUM
Balance Of Power. IMSA "equalizes" different car types to where they have comparable performance on specific tracks. They have a wide range of variables that they set. Minimum ride height is one of them.
Old 01-20-2018, 02:03 PM
91K-Man
Registered User
91K-Man's Avatar
Aero results on an SD stick provided, coaching available.
Hi all, AudiOn19s , Drive 7 hrs to Toronto and we can blow your car in a full scale windtunnel, rake the car 1/4" a time. Then you will have you answer. Mantissport is planning 2-3 hrs in February in the tunnel. Anyone with interest $1k for a base blow, $1,500 we get 3-4 blows in with changes made. 905-844-6219
Quick Reply: Chassis Rake and it's effect on balance / handling
