Lighter battery?
Lighter battery?
I'm looking for a battery "similar in size" to OE per SCCA racing rules. The Optima weighs nearly the same as OE and I cant use the little Odessy due to size.
Anyone found anything else?
If you want to save some money on a braille battery look for the Deka brand. Theyre usually half the price, and made by the same company that makes the braille batteries. I dont think either is legal in scca though because of the similar size requirement.
Uhhh... IAt the risk of revealing too much...
Most large cities have a battery re-cycler/re-builder. Purchase a lighter and smaller battery. Buy an empty battery case. Put small battery in large case, connect properly and reseal. I am sure you understand what I am getting at... unless they take the battery out, it all looks stock!
-P
-P
Wouldn't you still need to fill the case with fluid (acid)? Granted that isn't as heavy as larger lead plates, but some of the advantage dissipates. AS
