RA-1 tire wear question
Originally Posted by Veloce Raptor
RA1's get better & better. They are at their best immediately before they cord.
Well, first, Bryan, would you trust your race to tires about to cord? I wouldn't. Second, maybe they behave differently on ultra-light cars like SM's, but in sedans, they behave just as you describe (inverted bell curve) but significantly improve towards the end, irrespective of 2 heat cycles or 22.
Prior to my Hoosier addiction I ran RA-1s for about 3 years, probably 9-11 sets . I got a zillion (50+) HCs when I started, but as I got faster that number dropped quickly. That last three sets (all shaved) lost quite a bit (almost a lot) of grip in the rears on HC 27 or 28, all three sets did that with no signs of cording. The rears would give up without warning at mid corner or exit, almost like they had too much air in them….not fun.
A google search found that some of the spec miata guys toss theirs after 12-15 HC, or make them practice tires.
My experience is that they will heat cycle out before they cord.
Originally Posted by Chris M.
Is this also true for MPSCs?
They should not be "flipped on the rim" though, since they use different rubber compound for the outside and the inside.
when i get the WC tires, they have about 2-3 cycles on them. this means basically, i have a new tire! Ive heard that the new tires have maybe .25 seconds in them, and thats the reason for them going new during qualifying. (also, if they are wearing an edge, they dont get a blowout for going beyond cords in the race) However, there are several cars and drivers that leave a race and practice set with an even wear pattern. thats when i grab'em.
After that, i can get amost a full season of 3000miles of commuting as well as all the practice and qualifyiing for a 11 race season. (and thats on a near 3000lb car with 320rwhp)
my last practice session at T-hill found my fastest time on tires ive been using since last season. even faster than my qual and race times. the rears are getting very bald looking, but are still gripping quite well
mk
mk
Originally Posted by Bryan Watts
Interesting...my experience has been different. I noticed a definite drop off in times after the first 2-3 heat cycles when I ran them in Spec Miata...after the drop off though, they did seem to last at the same grip until they corded. None of the Spec Miata or World Challenge guys ever seem to be running corded tires. They tend to play by the 2-3 heat cycle rule as well.
Originally Posted by Astroman
...Also, my mechanic (who used to race) told me that running directional tires "backwards" was a bad idea because of the construction of the tire. Is ...
Moderator and 993 whisperer
I don't personally use a pyrometer, but the psi you want to shoot for is between 39-41 pounds. Keep a little notebook -- what track, weather that day, etc., and the recordings of cold and hot pressures. Eventually this will become committed to memory, but in the beginning, it's a really good tool to use.
