Mobil 1 Oil forumulation again
Super Moderator
Needs More Cowbell
Needs More Cowbell
5 year shelf life.....
Originally Posted by M3Pete
Can someone confirm or deny that synthetic oil has a shelf life and if so, what is it?
http://www.mobiloil.com/USA-English/...helf_Life.aspx
Administrator - "Tyson"
Some threads Doug Hillary suggested on this topic:
https://rennlist.com/forums/993-forum/342882-oil-again-mobil-1-15w-50-new-formulation.html
https://rennlist.com/forums/911-forum/341405-oil-question.html
I understand Mobile 1 is not 100% synthetic although I am not sure what percentage. I switched to Amsoil which is 100% synsthetic and have seen less oil use. Where I used a quart of 15-50 M1 on a race weekend I now use .25 to .5 quart of Amsoil 20-50.
Mike
Mike
as far as shelf life, keep an eye out for settling. The additives will settle to the bottom. They say it'll mix back in but I tried and couldn't get it to mix on a two year old bottle of Quaker State Synthetic. I also experienced this with another brand but can't recall which. It was about 18 months old. It's easiest to see if the oil is in a clear bottle.
Also keep your 50 gallons out of the cold. Oils don't like cold weather.
