Care and feeding of a trailer...
Originally Posted by Z-man
As for a weight distributing hitch - I have considered that, but I'm not sure how effective it would be. I figure the trailer probably weighs in around 1500 lbs, plus my 3000 lb car, plus 500lbs of gear, and I'm at 5000 lbs. My tow vehicle is rated at 6900 lbs pulling capacity. Is that enough of a cushion, or should I go with the weight distributing hitch?
-Z-man.
-Z-man.
BTW... I don't use one on my dodge, but a 2500 dodge is such overkill for an open trailer I can get away with with it. It has 10,000 tow rating and 1,000 lbs on hitch (wt distrubuting) then there is that 3300 lbs payload. If I towed and enclosed box I would get weight distributing hitch to ensure balance.
-Z-man.
-Z-man.
http://www.reese-hitches.com/WD/dt_strait_line.html
Cows-4-Rent
How long is the trailer? You can mount some galvanized or black pipe vertically in front of the car and bolt them to the trailer. Put your tires/wheels over the pipe and tie them down. Saves a bunch of fuel economy over a vertical tire rack
I have a spare for the trailer -- it's currently in my garage.
The trailer is 18 feet long, so I definately have some room to work with in getting a non-conventional tire rack solution.
-Z
-Z
don't worry about the wood Z. if you do anything don;t paint it, seal it. Paint may be slippery when wet. Also I did the bearings and shackles on my open trailer but it was 10 years old. I think you just need to do a service. My ATC is up at Perfromace now. Andy
Trailer Wheel Bearings
"2. Any ideas on how long the wheel bearings last on such trailers?"
If you just bought a new trailer, I'd say two years. If your trailer is used, I'd say, repack them now, and every two years thereafter.
My personal experience on this is from not doing so. My trailer stranded me for a full day enroute from Dallas to Road America, about 150 miles from any city. The wheel bearing wear was so great that I had to get a new axle before I could proceed.
Wheel bearings are things that are easy to overlook or take for granted, since they don't get much use. I won't make that mistake again.
Good decision on buying a trailer, and on seeking advice. Best wishes.
4. At this point,, I'm not going to put a tire rack on it. Has anyone found other creative ways of mounting tires on a trailer like this? I was considering mounting a couple of spare tires infront or or behind the car.
-Z-man.
-Z-man.
-Z-man.
-Z-man.
