Trailing Arm Failure
Has anyone ever heard of something like this? This is a 944 rear trailing arm from a race car. I've been running solid bushings and mounts on the rear suspension for two seasons. Problem or coincidence? The front control arms failures are well documented, but I've never heard of this before. It happened on the turn-in to #1 at Summit Point. The resulting impact left me with with more than just a trailing arm to replace!
Steve
Steve
wow, i have never seen that before. it looks like a stress fracture. maybe a bad trailing arm? were you hitting the ripple strips at the time it snapped? of course solid bushing will transfer more of the impacts through the trailing arm, this in turn could and should shorten the life of the trailing arm and assosiated parts.
Sean
Sean
I have never seen that. I would guess it was either remants of crash damage or some sort of isolated material defect. I know no 944 spec has experience that and I don't believe I have seen that in even 500 hp 951's using 13" wide slicks. Concern has always been in the front
I think by solid bushings he means spherical rather than rubber.
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Jason Burkett
Hmmmmmpf;
Yet another vote for steel.
By the looks of that, the break is completely clean and shows no sign of gradual deterioration. Many times when something fatigues and breaks, it will do so gradually, offering you a visual time line. You can see clean and dirty areas in the fractured surface that tip you as to where the failure started, and what was the last area to hold on. This one looks like a single incident clean failure. A porous casting indeed seems probable. That or some previous impact that you are unaware of.
Documenter of Ineptitude
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I know of a 1978 928 that had a similar thing happen on the way home from a DE that it was being used in. About 10 miles after it left the track :eek
Bit of a background on it.
Around 500lb rear springs on it. Big sways. No accidents in the history of the car. Driven in DE's for the last 16 years with suspension slowly getting built up through the first 10.
BTW. Glad you are okay. Hope the car goes back together well.
Was it the bottom front A-arm on the 928 or the rear K bar?
Because the 928 has a steel rear K-Bar.
