Instructing at 11/10ths
Local Knowledge, my boy;
The Heel is one of the tougher turns there in the wet. Always has been. If you go to a pro race, at least 70% of the wet moments and wrecks will be there. The braking zone is famously unstable. Fortunately, the runoff allows you to just go straight and toss it in the stones if need be. So too are the transitions from the cement to pavement and back again getting wacky. Unfortunately, the track only offers you a nice trip into the Armco on the right after the apex. You're only real chance is to recognize it really early, straighten signficiantly, brake on-surface, and try to tip-toe up the grass on the right before the Armco gets too close.
I make extra sure NOT to let my students run on the cement in 8. You need to do a pretty drastic rain line there. Turn in is WELL PAST the cement arc with a very large input to gain significant change in the cars direction, and then an equally significant unwind of the wheel. At this point you can then CROSS the cement as close to perpendicular as you can manage, and exit well INSIDE the cement arc, passing at least a full car width INSIDE the usual trackout point.
The cement used to be AWESOME in the rain. With some spots getting pretty polished, it is now fairly psycho.
John's advice is to be taken seriously, here as elsewhere. The cement is ice-like in the wet, and takes much longer than the asphalt to provide adhesion again again in drying conditions. I had a significant power-one oversteer exiting T7 and again in T8 when the asphalt gave good grip but the cement did not.
Rennlist Hoonigan
which cost no drachmas
I think the Glen is much different than many tracks - offering mucho different conditions at different parts of the track. The weekend we had rain in the boot and dry track everywhere else. The coupled with changing conditions makes things very interesting as an instructor....
I find students have a real tough time being able to gauge appropriate speed in the rain. They are either very conservative (easier to work with) or overly enthusiastic (a real handful). Overall, I try to get them to start nice and slow with very early braking and then very slowly work up to quicker speeds. I try to do all this at speeds appropriate to the conditions in a manner that we never lose control.
Overall, I like teaching in the rain. I think it's sort of like a wet skidpad - it lets you get the feel and mechanics of driving at a reduced speed.
Just my $.005.
Matt
Just my $.005.
Matt
This sounds as though your experience defines "s--t happens." Other than what has been discussed already, keeping the student from "over shifting" around a wet track; accelerating full bore out of the turns; generally, being "un-smooth" with steering, shifting, braking and acceleration all can lead to an unhappy finish.
Yes, driving the rain line is a great eductional experience, but keep in mind, if the student is not happy driving in the rain, then leave it alone...don't push. If an instructor (and, I'm certainly not saying you did) kind of "insists" on having the student drive in situations which are of concern to the student such as rain, then an added risk falls upon the instructor...just my .02
Rennlist Hoonigan
I don't want my comments misunderstood. I would never make a student drive if they were not comfortable. Dry or rain. I think this is one of the most important things of instructing. Everyone comes to the track with a different goal / priority and we have to be aware of that.
Matt
Matt
Originally Posted by DrJupeman
Secondly, the key to instructing is being ahead of the car and the student. You help them by anticipating things before they become severe and well before the student is aware. The challenge is recognizing a problem yourself and communicating a correction in time.
Originally Posted by TD in DC
Really, the same is true with non-ABS brakes as well. Modulating brakes manually works if your car is going longitudinally, but not if you are going laterally. Even after you go both feet in, it is possible to "drive" the car as necessary to avoid obstacles, or at least create a better angle for impact. Now, trying to explain these things to a student when you are in the middle of a depends moment is another subject altogether.
Originally Posted by RedlineMan
...So too are the transitions from the cement to pavement and back again getting wacky. Unfortunately, the track only offers you a nice trip into the Armco on the right after the apex.
I'm beginning to wonder if John (Redlineman) was sitting in the back seat with us...
-Z
Hmmm...
The odd thing is that not all the cement is polished. Only certain spots. It used to be universally fabulous when wet. Now, for instance, there is a nasty slick spot just past the apex to about half way out to track out coming out of The Toe. Even I can brake traction there!
8 is just wierd. Like I said, I take an extremely late turn in, really squaring off the turn in. This means turning very sharply all in one small spot. Then I can accelerate fairly hard out of the turn, crossing the cement quickly, not relying on it for grip.
Anytime you've let the rear get away from you in those situations, you've been slow on the draw. It's not snap oversteer, it's slow recognition! Live & Learn. It's a tough lesson that way.
Ugh. Racing there in the rain, even with Hoosier wets, sucks.
Originally Posted by Ed Newman
Does anyone else find that instructing in the newer cars (Cayman/997) is MUCH harder since the passenger (instructor) can feel a damn thing!
