Any recommendations for track wheels?
#31
Rennlist Lifetime Member
Originally Posted by richard glickel.
I'm fairly certain that "replica" wheels are NOT permitted for PCA track events.
Richard
Richard
For Prepared Cars...
D. Wheel type, style, and diameter are free, providing wheel meets or exceeds factory safety specifications.
E. One inch wider than originally supplied wheel and any tire combination which fits inside the stock body without rubbing and without modification exceeding “rolling” or “grinding” of the outer fender lip is allowed.
F. Wheel spacers are allowed for tire clearance only. The use of overly wide spacers which place higher than normal vertical loads on spindles and bearings is a safety hazard and will, therefore, not be allowed.
For GT Classes...
Tires and Wheels - Wheels two inches wider than originally supplied and any tire combination
which fits under the fender is allowed. Tires and wheels must comply with Stock rules 3A, 3B, 3C and 3D.
#32
Addicted Specialist
As Oddjob said, crack happens ...ok so he didn't quite say it that way
But it's true. It may not happen to everyone, but cracks occur more regularly than never. My point is this should be expected, and wheels are a consumable cost like tires and brakes. BUT, that's one hell of a consumable expense! So if your budget includes wheel replacement, go for the lightweight forged options. I'm a hack, myself, and just want to go out and have fun out there, and minimizing my costs IS very much part of the fun. This is one of the reasons that I've always chosen OEM Porsche wheels for track work ...proven strength, reasonable cost, and arguably the best performance/$ ratio out there, IMHO anyway.
Edward
Edward
#33
Originally Posted by Oddjob
OEM Porsche wheels and other high quality/brand name street wheels typically hold up pretty well (commonly a higher quality pressure casting), but they are heavy compared to race wheels and are expensive compared to the replica/copies. Everything is a trade off....
For DE, there really is no reason to go with a lighter, less durable wheel, unless the ego requires it. Then again, there's also no need for R-compounds and modified cars - if we all took this DE stuff seriously, we'd be learning to drive in rear swing-axle 356 coupes!
My $0.42,
-Z.
#35
Richard
Richard
Never been a rule that I have come across at any PCA event (various regions). Not saying that there isnt a region or two with this rule, but it certainly is not common. You see a lot of Fuchs replicas, the Mille Miglia and a couple other brands of the 964 Cup I's, 993 Cup II's, and some 18" 993 Turbo Twist replicas all over at track events. They are not dangerous, but they are softer and more prone to bending if you hit a good pot hole or run over rumble strips hard.
#36
Originally Posted by Z-man
Actually, I've found some great deals on Porsche OEM wheels. I have typically paid $100 per 16" wheel, and the wheels I've bought include: 968 5-spokes, Design-90's, and 944 Turbo cup (forged alloy) wheels. All for around $100 a corner.
My $0.42,
-Z.
My $0.42,
-Z.
The current aftermarket copies in 17" and 18" are cheaper than the OEM wheels, if comparing new to new, or used to used. Yes, you can probably get a set of used OEM wheels for the same or even slightly less than a set of new replicas.
Since the orig. question was for a 997, Im guessing he is probably going to look for 18". I dont know the 997 rear track width, and what offset wheels they use - so I dont know if the 993 Turbo and 996 Turbo rears will fit (around et 40mm). So he may be limited to the narrow body wheels, but there would still be several options available in OEM wheels (narrow body 993 Twists, Sport Design, Sport Classic, etc...). Would guess that the entry level price for these wheels (good condition used) would be around a $1k and well upward.
#37
#38
Originally Posted by Bull
In the past few years, I have seen two replica wheels, one Cup I and one Cup II, where the center section has broken completely away from the rim......not just craked, but where the rim and tire are GONE and the car is traveling on the "spokes" of what is remaining of the wheel. Looked dangerous to me.
#39
#40
Originally Posted by f1rocks
I bet that really screwed up the braking points.
#41
Originally Posted by Rick
I've not heard that...if that were the case, how are we permitted to run Forgeline, Fikse, Kinesis, etc? Below are the portions of the PCA Club Racing rulebook that pertain to wheels. It would be interesting to know if/how some of the replicas do or do not meet 'factory safety specifications.' I would never think of running some of the off-brand replicas anyway.
Anyway, rules (or no rule) aside, regardless of what you're riding on, check those wheels & tires for wear and defects before and after (and, depending upon what transpires on the track - during) each event.
Richard
#42
Originally Posted by MPD47
I loved my CCW's, decent pricing, light, looked pretty good too. Available in nearly any sizes.
Complete Custom Wheel was the answer for me. John at CCW has geared his buiness for racers. In fact, most of his customers come from referrals form other racers. Just look at any SCCA national event and you will see them all over the place. Classic 3-piece race wheels are $2K a set for any width or about half the price of those other brands.
You can't beat their service either. I have a friend who had a set of 2-piece welded Forgelines made for his Supra. They were leaking air at the welds twice. Each time, it took Forgeline 6 weeks to 2 months to fix and send them back. When he switched to CCW's and had a driver induced incident on the street with a curb. John had the wheel rebuilt and back to him in a week. I ordered mine a couple of weeks ago and John had clear annodized (light gray) centers and the outer halves in stock to build them. They were put together and shipped in 2 days.
Last, I would recommend going to Michelin Sport Cups over RA1s. The first issue is that Toyo has very few and not the right sizes in 18"s. They only have a choice of 275/35's or 305/35's for the rear. I had them for a Miata I used to own and they are a good tire, they just aren't as fast as the Michelins and tend to loose their grip when they get really hot. I am running GT3 sized Sport Cups on my CCWs. For a 997, I suspect John can do a set of 18x9.0"/18x12.0" and you should be able to run 235/40 and 315/30 Sport Cups on that setup.
#43
Richard
Richard
Reducing rotational mass offers significant improvements in accelleration and braking as well as reducing unsprung weight... light wheels are definately a high priority performance issue
#44
too bad they don't carry anything wider than 10". i would like 18x10" and 18x12" for the track
Originally Posted by bruinbro
If you want a cheaper serious alternative...
Bro
Bro
#45
Bro
