Anyone running 245/275 on your SC or 3.2 911? Question
Hi folks. What did you have to do to make these fit? I was walking around the paddock at Road Atlanta and noticed this combo on most competitive SCs and 3.2s. Of course I forgot to ask all the right questions.
Did you have to move the steel oil lines on the passenger side? What other changes were necessary? I think I have the correct offset.
Tristan
Tristan
I am running 245/35/18's and 275/35/18's on my SC. While there is a slight polishing of the lines in one spot I don't think it's going to require any action. I am running custom CCW wheels so I can't comment on the offset, only to say the tires JUST fit. If you have room on the outside you might consider having 4mm spacers milled down to 2mm in the rear. I'm sure you are already using steel lug nuts so you know if 2mm will work on the lugs you have or not..
