Potential Caution for 944s at Shenandoah -- Updated with Some Data
Old 10-26-2005, 01:59 PM
  #61
joseph mitro
joseph mitro's Avatar
TD - are you doing the work yourself? i had my machining done at a shop for about $500 for everything including cleaning, machining, and balancing. i also used forged rods in the rebuild. get some of those.
the rebuild kits are pretty inexpensive, but if you get both upper and lower kits and replace all the sensors and belts and clutch and so on, it can get expensive. my total cost was over $5000 doing all the work myself.
it sounds like you've already started...you've got a stand. my other suggestion is to get an impact wrench and air ratchet. it will save you lots of time on dissassembly, and there are some things you can use the ratchet for on reassembly.
Old 10-26-2005, 03:14 PM
  #62
M758
M758's Avatar
Impact gun helps for flywheel bolts and main crankt bolt too.
Although I have air tools I tend to use the manual stuff more. I like that I can feel things.
Crazy might be I...
Old 10-26-2005, 03:23 PM
  #63
APKhaos
APKhaos's Avatar
Need to be ultra careful with impact tools on these engines. My experience with the dissimilar metals corrosion that can lock threads tight is that too much force can strip threads and/or break fastners fairly easily. I had air tools on hand during my rebuild last winter, but used hand tools almost exclusively. Air tools are handy and quick, but they can cause problems quickly. Better to go a little slower and feel what's happening before the problems become major ones.
YMMV etc.
Old 10-26-2005, 03:41 PM
  #64
kurt M
Mr. Excitement
kurt M's Avatar
Todd will have the same tool pool to work with as Tony had.
Old 10-26-2005, 03:43 PM
  #65
TD in DC
TD in DC's Avatar
and more than a little help from my friends.
Old 10-26-2005, 04:25 PM
  #66
Carrera51
Carrera51's Avatar
Hollywood, you now wrench on water pumpers?? Just because the 944 has the same number of cylinders as the 912S doesn't make them the same
Old 10-26-2005, 04:43 PM
  #67
APKhaos
APKhaos's Avatar
It was kinda like the Speed program 'Build or Bust'. I worked on the rebuild in Kurt's shop, while he came in every now and again to have a little chuckle at the lastest dumb thing I've done and to bail me out when I'd struck a problem that took some real skill to resolve. Wait for the series - it should be hilarious.
Old 10-26-2005, 04:45 PM
  #68
kurt M
Mr. Excitement
kurt M's Avatar
How much diferent could they be? They have a gear driven cam, finned jugs, pushrods and carbs don't they?
Don't let Tony fool you, he did a nice rebuild oon the 951.
Old 10-26-2005, 06:56 PM
  #69
Carrera51
Carrera51's Avatar
I would say he did. His motor didn't blow up
Old 10-26-2005, 07:07 PM
  #70
FormulaOne10
FormulaOne10's Avatar
I always fill about .5-.75 qt over full since my car (and many others with poor valve guides) spends about .5-1qt per 40 min session. I figure the first few laps are for warmup anyway (i.e. slower turns/braking) and will burn a bit of oil off(engine is usually working just as hard on the straights). My goal is to always keep a bit above the "full" level. I personally think the cavitation issues are overstated here (unless you throw in an extra gallon or so ). I still haven't replaced a rod-bearing...although I will be doing them this fall if I don't buy a new track toy! I would think that cars pulling more than 1g (most-track dedicated cars) will start to run into some issues though. Who knows...I don't have any data, only my emperical observations, so I could be wrong.
Old 10-26-2005, 07:13 PM
  #71
TD in DC
TD in DC's Avatar
My data showed that I was pulling 1.2-1.3 gs (and a handful of 1.4gs ) over the fateful weekend.
Old 10-26-2005, 07:36 PM
  #72
joseph mitro
impressive. on track tires? what type of suspension setup do you have and how stiff are the springs?
Old 10-26-2005, 07:39 PM
  #73
FormulaOne10
Wow...1.4g sounds extremely high. In my car with R-compound, upgraded shocks, springs, sways I can only pull ~1g according to my DAS. Maybe try filtering the data a bit to smooth out the peaks.
Old 10-26-2005, 07:42 PM
  #74
TD in DC
TD in DC's Avatar
Joseph:
I was runing Toyo RA1s on 15x8 Fuchs all around. All I know about the suspension is from the seller's flyer, which states the following:
FRONT: Turbo shock mounts, strut tower brace, cut down 300 lb.springs, shocks. Heavy Porsche MO30 30MM front sway bar. High performance solid bushings. High strength steel a-arms (This car is lowered approx 2 inches.)
REAR: Porsche MO30 26 mm. sway bar, gas shocks.
Desirable 30 mm. torsion bar. Solid bushings.
I don't know how accurate the DL-1 is or what is "normal." I was just a little surprised when I looked at the numbers.
Old 10-26-2005, 07:45 PM
  #75
TD in DC
TD in DC's Avatar
I just looked at the DL-1 data extremely briefly, and I don't know how accurate it is. I also don't know if the camber of Karussel could affect the readings. Finally, the unit is level from side to side, but the face of the unit improperly tilts up towards the front too much (installed on a driveway that wasn't level). Nonetheless, I was a little surprised. The 1.4 gs were definitely outliers. Most were 1.2 with several 1.3s.
Quick Reply: Potential Caution for 944s at Shenandoah -- Updated with Some Data
