Confessions of a Former (and potentially future) HP Junkie
#61
Originally Posted by sjanes
Hmm, I find that the 911 (the older cars at least) don't want to turn at all if you try the enter the corner on the throttle. For tighter corners, a little (or a lot) of trail braking is very useful in getting the car to rotate, but even in the faster corners, I don't complete the brake release until I'm starting to turn the wheel. This keeps some weight on the nose of the car to help it change direction. There are very few corners that I can think of where I'm fully off the brake and on the gas while still in a straight line. Now once the car has started to turn, the throttle is needed to settle the back end.
While there are a number of corners I trail brake, I do it more out of a desire to be smooth and speedy, rather than trying to get the car to turn in (which TB obviously aids in). Persumably for most corners one has already down some slowing down, which has caused weight transfer which facilitates rotation. I haven't particularly noticed in my 911 a tendency to be obstinate about turning in. (This might be down to the fact that I'm too slow, overbraking or simply a lummox of course) I was observing that I've not found the 996 wanting in either precision or responsivness if your doing something with the car, if your just coasting or on maintaince throttle, then indeed it's steering seems too be less satisfying than other cars I can think of (like a 944!).
#62
Late the party, and on a strange computer to boot;
Todd; I see your "problem." Too much roll stiffness, and a basic "imbalance" in your spring rates. 300lb front springs are not much compared to a 30mm t-bar. Add in those M030 bars that are too big for a car that light, and that would make for a twitchy car.
The dirty little secret about sways is that they don't control it on track cars! They only control sway on soft street cars. On stiffer track cars they are relegated to balance tuning. Your bars are so stiff compared to the springs that they are effecting weight transfer too much; actually decreasing grip in transisition by taking load off the tires at the critical moment.
I use Weltmeister bars, and they are borderline too stiff at 28mm front. I have it at full soft and still have a bit too much roll stiffness. I have to be careful in trail braking because of that.
Joe - GET RID OF THE REAR TOE OUT. If you can control a toed-out car, you are either Senna or you are going SLOW. Toe out is diabolical. Itmust be absolutely EVEN side to side or it will bite you. It also makes braking a real adventure. It really is not the thing to do on that car.
You should go with factory 5/64 total toe in until you get more seat time and then work your way toward 0 toe, but only if you feel you need more rotation for turn in.
Reporting Live from Brockville, Ontario.
#63
Originally Posted by TD in DC
The good thing about starting with the 996 is that I am not afraid to go pretty fast into corners (although I am sure I can enter much, much faster). I am not sure that I would have felt as confident at speed if I has started from day one in a 20 year old car. I guess I will never really know
#64
i definitely appreciate your input, though. wish i had the same suspension knowledge you do
