Aftermarket spring plates
Anyone know if ERP or anyone else makes aftermarket spring plates for a 944, the type that is used when deleting the torsion bars, such as the type pictured below? I’ve seen them for 911’s but never 944’s. I think the 911 spring plates are longer and wouldn’t work in a 944.
Kelly Moss Racing used to. Im not sure if their rear end kit is still available, and they were some pretty good cash. It also used tapered roller bearings in place of the rubber bushings. This requires machining the torsion bar tube and carriers. Last I checked, their website has not been updated, so you might have to call.
Thanks Jim, I'll check with Kelly Moss.
The Kokeln unit is nice, but I believe you need to replace the whole torsion tube housing, and last I checked that piece was about $7k.
