Roof Rack Tire Mount Completed
#48
I agree with Jack...
There is a load limit for the roof racks. Eight (8) tires and wheels is probably twice the amount recommend by Porsche. I believe on a 993 the suggested weight limit is 180 Lbs.
Once you have trailered the car....you'll never go back, IMHO. At least I wont. It is so incredible to arrive at the track with the car ready to go. Drive it off the trailer and head for the grid...it is that simple.
#49
Originally Posted by JCP911S
Found this photo of the old rack... 2 sets and no problems...
That looks even more nuts than my "I bet I can strap something else to it" trailer.
#51
Originally Posted by sweanders
Aren't you guys worried that you are exceding the max roof weight? IIRC it is less than 70 kg's.
I had no sign of crack or bending... got some scratches though
Broke down and bought a trailer and truck.... alot easier to get to the track, but more of a PIA in other ways....
#53
Just reviving this a bit. Just bought a rack...mostly as a "what if". Curious as to what people are doing now. The rack is rated at 165 lbs. My wheels are supposed to be 20-21 lbs each, so no way I'm close to the 165 total.
I'm inclined at this point to mount the rack with the cross bars close together ala' post above:
Might be a little less aero than the flat layout, but probably much easier to build, install, tear down, and store. Not to mention probably pretty easy to tie down the tires too.
I figure put them like above, put a bar through them all, then ratchet strap around/through the tires and ratchet strap the cross bars to the center bar going through the wheels.
Thoughts?
Thoughts?
#54
